New to diesel, looking for general tips.
Oliver Closehauf
Cincinnati
2005 Laramie
Cummins 5.9
Recently bought my 05 that was very well cared for as it has 272k miles on it but you would never know it. I bought it from the second owner who is a cop, who bought it from a friend of his at 200k. Truck even has a name, Big Blue. In my mind Big Blue has done its "work" and now will enjoy its retirement by being loved and pampered by me and taken on the occasional trip to Home Depot for lumber.
Anyway, I'm keeping the block heater plugged in at 40 and below, I bought a Battery Tender just for it and I try to start it every 2-3 days. Problem is I don't really "need" the truck on a daily basis as I work from home, but when you need a truck and don't have one, well you know.
I filled it up last time I went out, added the requisite amount of diesel kleen, Oil was just changed, all major mechanical items have been addressed by the PO, I've been doing the OCD nit picking stuff I like to call "Christine-ing" if you get the reference to the movie.
So what I'm looking for mostly is since this truck will just in my driveway and be driven once a week if I'm lucky, what do I need to stay on top of? Mainly I'm talking diesel. Things not covered in the owners manual.
Dennis Shellito
Ft. Morgan, CO
Cummins IBS
Well, during warm weather you need to run the fuel out of the tank every 6-8 weeks to keep moisture from forming in the tank. Moisture will invite algae into the tank and then you will have serious trouble. You should probably add a good algaecide in the fuel tank at every fill up. I have used Power Service BioKleen and it does a good job as long as your truck doesn't become infested with algae. I have seen these 5.9L Cummins trucks run for up to and past 1,000,000 miles so don't think your truck needs a retirement home. The more they are driven (sensibly) the better they like it. Good luck with your new-to-you diesel!
chri5k
USA
Diesel
Three things; clean air, clean fuel and clean oil. Keep up with the maintenance on these three items and you will keep the engine happy.
Oliver Closehauf
Oliver Closehauf
Cincinnati
2005 Laramie
Cummins 5.9
algae ??? What's "warm weather"? I'm in Cincinnati, so may as well be jungles of Panama as far as humidity is concerned. Never heard of algae being a problem. It's always effen raining. Hell it's raining now.
bm02tj
B C Canada
All above and do not shut off engine after it was under load let idle for short while to protect turbo and head
Dennis Shellito
Ft. Morgan, CO
Cummins IBS
The reason I mentioned "algae" is because some of the folks that have diesel powered motorhomes that live in a high humidity location have had serious algae infestations in their fuel systems from leaving them parked with the same fuel for extended durations. I filled my 2011 CTD Ram up at a little corner station in Lincoln, NE once when I was running low on fuel passing through town and I got some algae in my fuel system. The fuel mileage dropped from 20+ down to 10 mpg almost immediately and the engine started running sort of rough. When I got home in CO I changed the fuel filter and the one I removed was full of gray sludge. I started running algaecide in the fuel and changed the filter again after 1,000 miles and it had a little gray sludge in it. I eventually got the truck back in the pink after repeatedly using the BioKleen. I mentioned this simply because you said you wouldn't be driving your truck very often, and sitting diesel fuel is a magnet for algae in warm damp environs.
Administrator
If you start the truck take it out and get it good and hot but don't start it to let it idle for a few. Diesel don't build heat until they're under load and there's no real benefit of partially warming the engine. Your battery tender will keep them good to start.
Oliver Closehauf
Oliver Closehauf
Cincinnati
2005 Laramie
Cummins 5.9
So what about the use of the block heater? If I know I'm not going to drive it for a week but it's below 40 do I really need to keep it plugged in the whole time? Or just plug it in a few hour/ day before?
Dennis Shellito
Ft. Morgan, CO
Cummins IBS
Save the juice and plug it in a few hours or so before you crank it up. I leave my truck plugged in all the time during the winter as I never know if I will be driving it or not. My Cummins will start in very cold weather but I like the leg up, so to speak, to get it warmed up faster.
Administrator
As mentioned above, just plug it in a couple hours before. Buy yourself a smart plug with energy monitoring, then you can turn the block heater from your smart phone and see if you remembered to plug the truck in.
The CTD block heater is 750 watt so any of the smart plugs or timers should handle the power.
TimboRam77
Had a 05 Laramie 3500 longbed and sold at 120k. Hate hate hate I sold it. Run some biodiesel if you can get it. Crd loves b20. I ran b100 and b70 year round. I changed my fuel filter at every 5000 mile oil change. Bad fuel is bad news. Never mom and pops diesel. I made high quality potassium based bio that was extremely clean and the entire process was environment friendly. If it's an automatic, that is the weak link.
Gr8bawana
6.7 CTD
To the OP. Just remember that all this stuff about this or that being bad or having a bad design or you MUST NOT do this or that is GREATLY exaggerated.
Many many guys come here only to complain. These are very much the minority of very happy Dodge or Ram owners.
Oliver Closehauf
Oliver Closehauf
Cincinnati
2005 Laramie
Cummins 5.9
Right, thanks. I'm taking in everything and making my own decisions. I'm new to diesel, but not new. Cars and bikes have been one of my hobbies since forever. Have even gotten paid for it a few times in the past. Just didn't want to overlook something "every diesel owner knows" to do and have a pile of junk come spring.
CVX20
Ont,Ca.
2019 Classic Express
Worst thing you can do is treat it like a gas engine.They don't like stopping and starting,short trips etc...They liked to run and be worked.Harder worked the better.
powerhour
Clearwater County, Alberta
2005 and 2019 Classic
5.9 CTD and 5.7 Hemi
I live in Canada and I only plug it in the night before I go anywhere, thats overkill. You only really need a few hours before you start the truck when plugged in. I dont even bother to plug mine in until its at least 10F. 40F is still Tee shirt weather. Just make sure your batteries are good and you run a quality synthetic like Rotella T6
