New Wheels/Tire Width Question
ThunderMug95
North Prince George, VA
651B4AAA-A294-4F36-98B3-2745790D55D8.jpeg The shot is angled...slightly. no rub on control arms...slight rub on track bar but its because of the sidewall lugs on the Falkens.
That day I took the shot, it was aligned. But not very well. Took it to my NTB and had it realigned back in spec.
Just note, no fender flares.
bighammer
Traverse City, MI
2015 and 2003
Cummins
Go to rimsntires.com ... They have a comparison program on their site ... Plug in stock size, and plug in your new sizes, and it tells/shows you everything you need to know
This one works well too. Actually shows them side by side both diameter and height.
https://tiresize.com/comparison/
bighammer
Traverse City, MI
2015 and 2003
Cummins
The original tires looked tiny, so I put on 315/70-17 mounted on Hummer H2 rims. (from my old truck) I liked the height, but they did stick out a bit. I wanted narrower tread for snow, so I went with 275/65-20 and really like them.
Marshall
Sk, Canada
2014 sport
I do not understand why anyone wants tires sticking out from the fenders
BOWERSFJ
Uniontown OH
Personal preference, looks, and in some cases you add the width to offset an increase in height due to a lift, to maintain a stable center of gravity ... But mostly badass looks
gdawg55
gdawg55
GA
Thanks for the pic. What is the offset of those H2 wheels?
hodge-xj
5.9 cummins
Yeah it looks good I think. I had 35s on 20s before and it definitely looked stuffed. I do believe going from 20s to 17s and from 35s to almost 34s made it look good with minimal change. More side wall makes it deceiving.
How's it drive compared to the 35s? I got some 315s on 17s I'm currently running and when it comes time for tires I'm really considering dropping to the 285 75s. I don't really think it'll look all that different, and it should drive a bit better....still having this inner conflict.
Sent from my SM-N920V using Tapatalk
Dinky
Oregon
Looks a little better not stuffed. Cant tell any difference for performance. The ride is a little softer going from 20s to 17s. Your ride will be better since your 315 and I am 285/75R17
