Rear coil spring too stiff
Nelywood
Cordelia CA
Hello!
Looking for some help with my super stiff rear end on my 2014 2500 5.7 liter with COIL SPRINGS. Trying to mellow out the rear end so I can avoid the dentist to fix a chipped tooth!
TIA for any info!
White six four
Wisconsin
What are your tire pressures? Lowering them can help the ride a lot.
rzr6-4
nebraska
Shocks can make a huge difference if they're old.
What vehicle are you used to? A 2500 will never be as smooth as a 1500 or a car if that's what you're used to.
Riccochet
Somewhere around Charlotte
2020 2500 Laramie Longhorn
Why buy a 2500 and not expect a stiffer ride? It's stiff for a reason, payload. You can mellow it out by dropping tire pressure to 45-50 PSI at all 4 corners. That'll take some of the harshness away. Just air back up when towing/hauling.
If you're not towing or hauling heavy maybe get a 1500.
Choupique
Louisiana
Cummins
As others have said, dropping tire pressure when the truck is unloaded will give immediate significant improvement.
Daw14
If you add about 4 or 5 hundred pounds in the bed it will ride much nicer.
