Ring gear Size
mralaskan
Alaska
Hey
Can you tell the ring gear size on a dodge ram 1500 (2008) hemi 5.7 without tearing it apart? 10.5 or 9.25?
Wondering because Im looking for rear wheel bearings.
Thanks
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
stock for a 1500, i believe is 9.25"
manufactured by AAM
( AMERICAN AXLE & MANUFACTURING )
Ole Buck
South Alabama
Do a VIN decoder for your vehicle and it will tell you exactly what it left the factory with
HemiLonestar
MD
All 1500's/half tons from 1972 to 2008 used the same basic leaf spring 9¼ rear (slight variations over the years). The 9¼ continued into the 4th gen run for a bit with coil springs until replaced with the ZF axle. I had a factory installed 9¼ rear in a 1974 Monaco that lived behind a mildly built 440.
