Solo Performance Exhaust products at Got Exhaust
Nick@GotExhaust
Preferred Vendor
SC
Got Exhaust is now offering Solo Performance exhaust products! Solo Performance offers high quality stainless steel performance exhaust products that are made in the USA
They offer several high quality options for RAM owners
-RAM 2500 Muffler delete kit for 2014-2018 RAM 2500 with 6.4 HEMI
Proudly Built in the USA! Heavy Duty Bolt on 4" straight pipe that replaces the factory muffler. This will increase the flow and volume of the exhaust. This exhaust has a Deep Aggressive Rumble. This muffler replacement does not require any cutting or welding to install. It gives a great performance sound that is deep, mean, and aggressive. Volume 10 out of 10. Fits all 2014-2018 Ram Hemi 6.4L 2500 Pickup trucks with the factory exhaust. This entire exhaust system is built from heavy duty Stainless Steel right down to the hangers and Welding. Direct fit and will clamp right to the factory tailpipe. No Welding!
-Mach40 Direct bolt on muffler kit for 2009-2018 RAM 1500 with 5.7 HEMI
Description
Solo Performance “Bolt On Direct fit Muffler Assembly” for the 5.7L Hemi Dodge Ram P/U from 2009-Present.
This no drone Stainless Steel Direct Fit Muffler Assembly gives you a Raw, Rich, Mean tone under acceleration while being non-invasive on the inside. This muffler assembly allows you to keep your stock tailpipes and have a performance exhaust system for a fantastic price. The Solo Direct Fit Muffler Assembly uses the Solo Performance MACH-40 free flow muffler which is smaller than the big body Mach-44 muffler used in the Solo Dual cat back exhaust kit for the Ram P/U. We use the smaller Mach-40 muffler in this application due to the resonators built into the stock tailpipes. Band Clamps are provided to complete the install. Affordable, easy to install by yourself and a great performance sound is what you get with the “Bolt-on-Ram-MACH40.” Enjoy Going Solo!
Exhaust Kit Specifications
* This is a completely stainless steel muffler assembly.
* Reinforced, heavy duty stainless steel hangers.
* Tig welded free flow muffler with heavy duty ceramic fiber and stainless steel wool packing to eliminate drone.
* Deep Rich American Muscle exhaust note on the outside.
* Non-invasive on the inside.
-Mach44 Dual Catback system for 2009-2018 RAM 1500 5.7 Hemi
Description
This Stainless Steel Mandrel Bent cat-back exhaust kit gives you a Raw, Rich, Mean exhaust note under acceleration on the outside while being non-invasive and a no drone on the inside. Customers have said that this system is like two exhaust kits in one with a deep performance exhaust note on the outside and remarkably quiet on the inside. This is your “everyday drivers” performance exhaust kit that sounds great but doesn’t rock you out of the cab or annoy your neighbors.
The MACH-44-RAM-DUAL exhaust kit starts off at 3” and then when it goes through the MACH44 free flow muffler it branches off into dual 2 ½” mandrel bent tailpipes. No need to remove your spare tire as Solo Performance has painstakingly bent the driver’s side tailpipe to accommodate the spare. We have band clamps on the two T304 Polished Stainless Steel Rolled Edge exhaust tips to give you adjustability in and out for a perfect fit every time.
The new Solo-Performance Tips are a larger diameter tip which fills the bumper cut outs better. Factory tips are 3.75″ x 7″ The replacement tips by Solo are 4″ (outlet) x 22″ (length) for a cleaner fuller look. Easy to install and fun to drive.
* This is a completely stainless steel converter back exhaust kit , all hardware included
* T304 polished stainless steel tips with a rolled edge and 4” outlet.
* Reinforced, heavy duty stainless hangers
* Mandrel bent pipes for increased flow
* Tig welded free flow muffler with ceramic fiber and stainless steel wool packing to help eliminate drone
* Deep Rich exhaust note
* Non-invasive inside the cabin
-Muffler delete for 2009-2018 RAM 1500 with 5.7 HEMI
Built in the USA! Heavy duty Stainless steel Pipes, Hangers, Welds & Clamps
Deep, Mean, Loud, Aggressive Rumble. This product does not bypass the emissions system in any way.
Direct fit / Bolt in Muffler replacement.
This kit replaces your factory muffler and bolts in to your factory exhaust pipes. NO welding required! If you want your Hemi to be heard then this is the kit for you!
Follow the links to the products or message me for details and pricing!
Options now listed for 2019 1500!
Dustin Steffey
Fernley, NV
Nick, I have a 2017 ram 1500 big horn crew cab.....can I get a quote on this or a good recommendation on some cost effective bolt on options as I want to do my exhaust while I’m installing my billsteins.
Thank you
Nick@GotExhaust
Nick@GotExhaust
Preferred Vendor
SC
Thank you
Sure! Ill send you a message now
Nick@GotExhaust
Nick@GotExhaust
Preferred Vendor
SC
mild and wild here!
Nick@GotExhaust
Nick@GotExhaust
Preferred Vendor
SC
The Mach 40 muffler kit will be quieter than most of our other muffler kit options and the delete kit will be our loudest option!
Nick@GotExhaust
Nick@GotExhaust
Preferred Vendor
SC
options for 1500 and 2500!
Nick@GotExhaust
Nick@GotExhaust
Preferred Vendor
SC
New product coming for the 2500 6.4 RAM. Its a muffler kit featuring the MR400 for those of you that think the delete will be too loud
Nick@GotExhaust
Nick@GotExhaust
Preferred Vendor
SC
price change on some items and the brand new MR400 kit is in stock as well as all other RAM specific kits
Nick@GotExhaust
Nick@GotExhaust
Preferred Vendor
SC
2019 OWNERS! Solo is going to be showing the 2019's with some love. We will soon be offering muffler delete kits and direct muffler swap kits for the 2019 RAM 1500!!!! Details and pricing coming SOON
Nick@GotExhaust
Nick@GotExhaust
Preferred Vendor
SC
We are offering Solo's muffler delete kit and MR400 muffler kit for 2019 RAM 1500's! We are waiting for info and pics to put it up on the site but if you would like to order either one just message me
HitchHiker
Delaware
Any sound clips for the 4th gen RAM 1500 catback kit?
