Tires for my Power Wagon
Kdoodah fella
Asheville
I kinda like the height of the 37’s that are on now but the width of them is too much. I think they are 12” wide. There is some rub on the sway bar when turning hard. Anything maybe out there that other owners can vouch for?
olyelr
Kewadin MI
Most common width for 37’s is 12.5”. There are a few skinnier at that height, but its very slim pickins.
Dont sweat the rub on the sway bar, it dosnt hurt anything haaaaaa
soapy
Northwest
6.4 hemi
37x11.50r17 Nitto Ridge Grapplers. I think that will be my next tire moving up from 35 inch Duratracs.
olyelr
Kewadin MI
They dont make that size in a 17” wheel that im aware of.
soapy
Northwest
6.4 hemi
Recon Grappler ATs is what I should have said.
62Blazer
Midwest
If you are running stock rims that is pretty common. Aftermarket wheels with less backspacing can solve that issue. Just don't go too far as then they will start rubbing the back bottom edge of the front fenders. Look up CJC Off-road as they have lots of information and videos of the right backspacing. New wheels are just another option if you otherwise like the current tires.
2Tallguy
San Diego
5.9 diesel
You need a 9" rim at the least for 37's to not wear prematurely down the center with decent psi in them.
