Torsion Bar Adjustment 2005 Dodge Ram
Lyle Longboat
2011 Ram 1500 5.7 Sport CC
Moosonee, ON, CANADA
Hello,
Checking to see if anyone knows the amounts of turns on the torsion bar keys to get the front up to 2”s of lift?
The reason I’m asking is I bought this 2005 with the TB keys already at 2”s and I replaced the whole front end. When I removed the keys, I marked on the keys/lower control arms and removed. I replaced and it doesn’t seem as though the front is even. I measured both sides and they are not even. Now, I didn’t measure before, however I replaced both front shocks with the same part numbers that came off (2” Rancho levelling shocks). So now I want to back the keys right out and start from scratch. Just checking if anyone knows how much lift is given per turn on the bolts.
Thanks for any input!
Ole Buck
South Alabama
take a measurement from the center of the hub/wheel to the bottom of the fender on both sides while truck is sitting flat and level. Next jack up the front until both tires are hanging completely free and suspension is at full droop. Back keys all the way out and start from scratch turning both the same amount of turns each time, keep setting the truck back down level till the amount of height you want is achieved. Keep measuring and counting. Then get an alignment and make a dentist appointment you will need both very soon.
Later2u
West Coast
So it already had 2" lift keys installed? Regardless, just crank the side that needs adjustment until both side are at the same height as you want. Turning them both the same amount of turns may not get you what you want, even. Things can be different from side to side. How much do you weigh?
Lyle Longboat
Lyle Longboat
Truck doesn’t have 2” lift keys, they stock. The front has 2” shocks and the keys where already adjusted for 2”S before I changed the whole front end. I’ll get the front settled once I’m done with the rocker panels and cab corners. Thanks guys. And I’ll use what has been suggested here.
