Transmission ID help needed
James Boggs
Have 1993 ram van B150 V8 with these numbers on the case just above the oil pan: 53007784 0727 7928
I looked everywhere to decode the model number so I know what part numbers to order. Date of mfg 4/93
Can anyone help me decode the transmission model number? Thanks
crazzywolfie
under the truck
best to call a dealer and see what the build sheet should say is in it. it has either a 727 or a518. a A518 is what i think should be in it but vans might be a bit different.
PaPitt
Stephenville TEXAS 76401
5.9L
i WORKED as a service advisor for 7 years. But that was about 11 years ago.
So I have forgot some .. But I'll say get your VIN no. & CALL your local dealer . RATHER DON'T CALL THEM go see them in person. You'll get better help.
Ask them to give you an options sheet for that Vin no. Seems like there was another sheet I could print . One was all the warranity repairs it'd had. & The recalls that had been done to it. Hope that'll help you.
mmerlinn
USA
181CID
53007784 is the service assembly number for the transmission
0727 is the date transmission was built (Dec 10, 1990)
7928 is the serial number of the transmission
Basically, this is an A500(46RH) non-lockup RWD transmission and not the original transmission in your van.
Yeah, thread is old, but OP never got his answer.
