Tuner ID
jwilliams3527
Birmingham, AL
Cummins 6.7
I recently purchased a deleted 2016 2500 with the Cummins 6.7. I was told it had also been tuned, but since I got it at a dealer they had no information on the tuner. I had not been able to locate a tuner until this past weekend I found a module under the dash on the passenger side. Can someone tell me what this is?tuner.jpg
Dennis Shellito
Ft. Morgan, CO
Cummins IBS
I have no idea what that is in the pic. If you have a "tuner" it would be plugged into the OBD II port. The truck can be tuned without any physical evidence, other than the missing junk, as my 2011 CTD is. The tune was downloaded via EZLynk directly into the PCM. If the truck runs good, I would recommend not changing the tune and do not let a dealership reflash the computer. You can purchase monitor gauges to see what the parameters are if that would make you more comfortable.
