Power lock actuators?
bembry
western NC
Are OE style replacement power lock actuators available for 1st gens?
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
Hopefully the OEM Actuators are available, but they may be hard to find.
Is there a way to open them up & rotating some parts to make it work
d100experience
Center of USA
318 LA roller
I wonder what the interchange between models is like. I installed factory lock solenoids in an early '70s Dodge car using ones from a much later Chrysler and the fit was perfect.
KEGGles
FL
5.9l Magnum
@bembry Not sure if you are looking for the latch portion or the actual lock assembly. I put this on driver side 55075873 and this should be passenger 55075872. If not this was the kit I was going to throw https://www.lmctruck.com/1972-93-dodge/door-parts/electric-door-locks in mine as someone looks like they were blind and doing electrical work on my doors. Only issue with the actuators listed above is the thread changes. M6x1x18
bembry
bembry
western NC
I don't need the latches, just the actuators/solenoids. That kit may be the way to go!
