Power Seat Wiring Harness
RAMbow
MaconGA
2015 FrankenRam (Limited Tradesman)
Deereguy, i plan do do this upgrade on the seats in the coming weeks/months after acquiring all needed parts. Im starting with a 2015 tradesman and plan to pickup 2015 laramie leather seats, heated/vented fronts and heated rear with the console. I do have the UAQ radio mod complete already. I do not intend to do the heated wheel if not necessary. Would you be able to build me all the appropriate harnesses i will need? Look forward to hearing from ya
Michel J Lausi
columbia, sc
2019 Classic Tradesman
3.0 Ecodiesel
Deereguy,
I am upgrading my seats to power/heated and vented on my 2019 Classic Tradesman as well as adding a full center console. Can you make me the appropriate harnesses?
Thanks,
jimlmackjr
Harker Height, TX
Hello
Not sure how active this thread is
I just installed in a 2014 Ram Express with manual seat
Added Rebel seat with power and heating
Would just like to get both drive and passenger power seat working
Is there a universal heat switch do I can power both seats
Charleston S.c
16 laramie
Deereguy,
I have a set of 2014 Laramie seats, power, heat and cooling for each front seat. I would like to install in my 2014 Sport which has manual seats. Also replacing my folding center seat with a 2014 Laramie center console and bezel. Any help would be appreciated.
Thanks
Charleston S.c
16 laramie
20210524_071542.jpg 20210524_071542.jpg I got afull set of power ,heated and cooled seats out of a 2010 and my 2016 has heated and cooled and power seats but the plugs dont match is there a harness to convert years
Ricks Ram
View attachment 248442 View attachment 248442 I got afull set of power ,heated and cooled seats out of a 2010 and my 2016 has heated and cooled and power seats but the plugs dont match is there a harness to convert years
These seats have completely different wiring and modules than your 2016. The 09 to 12 seats are completely different than the 13 to 18 and Classic. There is no conversion harness to make them work. These seats will not communicate with your truck's CAN system. You may be able to completely remove all the modules and harness from one seat and install it in the new seats but I haven't personally done it.
Sent from my SM-G981U1 using Tapatalk
Charleston S.c
16 laramie
Really I may be wrong on the year because the new seats driver and passenger are power driver has lumbar support and it has the 3 button setting on drivers as well and the harness pin difference is 4 wires total
204ramhemi
Canada
i am looking to install power(driver side)/heated seats in my 2017 ram 1500 sxt. i dont have heated steering wheel(wanna add one in near future), i did the 8.4 upgrade. looking for wire harness to make them work, ill include a picture of my factory wiring under my seat
Ricks Ram
Contact Mike @M2mods in the vendor section of the forum. He builds the custom harness for this conversion. It looks and works exactly as factory. You will have full power options, heat and vent if the seats are capable plus the heated steering g wheel. You can also have him include the wiring for memory seats if you happen to find seats out of a Laramie. When you purchase your seats make sure they are from a 13 to 18 Ram. The 09 to 12 seats will not work in your truck.
waynem
arizona
diesel
I have a 2005 Ram 3500 Laramie, old front seats were both power, and heated. We put in some 2018 heated and power seats from a wrecked Laramie (including center console). Need to get the jumper connectors or wiring harness to finish the conversion. thanks
Jonathan H
Garden Grove, CA
I have a 2014 RAM 1500 trademan, I purchased a set of 2017 Laramie power seats with heating and cooling. Can you help me with the electrical loom? Thank you
22hemi13
Tucson AZ
2014 2500 4x4
Is there a harness that will power the drivers seat coming from manual seat? Also I’m looking at the 2500 2019+ seat. Is there adapters to make seats work?
ZWagner
United States
3.6l pentastar
I have a 2016 Tradesman regular cab and looking to put 2016 laramie seats in. Can you help me with a harness?
Mrmead2
I have a 2013 Ram I just put Laramie seats in and need a wiring harness .
Seats are from a 2015
FinestTitan70
