Wiring seat
jamescox5345
Raymond wa
5.9 Cummins
I have a 2004 dodge 2500 and I installed 2017 seats that have power heat and air and I have the yellow connector on the truck side just wondering if you could give me information on hooking it up I sent pictures of drivers and passenger side truck only has power for drivers seat thanks in advance 1709764620839605538012041809833.jpg17097646532157589235181313577116.jpg
Mpgrimm2
Preferred Vendor
SC
2022 Ram 1500 (5th Gen)
5.7L
I will add this here also...
the 4th Gen 13-18/classic seats do not function independently from the BCM/control system in the truck. They require CANbus communication with a 2013-18/classic truck's electrical system (Seat Modules, BCM, & Center Stack Seat Switch buttons on LiNbus). You can't just add a switch and power/ground to get the heated/cooled features to work... There are temp sensors in the seats that also function as feedback to the seat modules)
The only thing you can do to make them move is to ...
Add +12v to yellow driver side connector at Pin 1
Add Gnd to yellow driver side connector at Pin 8
Add +12v to yellow passenger side connector at Pin 14
Add Gnd to yellow passengerr side connector at Pin 21
you can reference:
Tech authority schematic site changed names ...
I haven't used it since it changed.
Connector repair site is still free if you can find a set of schematics for your year to reference ...
Search keyword 'seat'... See attached 17 1500 DS seat connector info.
And then there's alldataDiy...
