REAR TAIL LIGHTS NOT WORKING
jillyj68
ADK, NEW YORK
1500, V6
I HAVE A 2020 RAM 1500, THE BOTH LH & RH TAIL LIGHTS STOPPED WORKING. CHECK ALL THE FUSES. ALL GOOD. BULBS GOOD... TOOK THE BULBS OUT. THE SOCKET WAS ALL CORRODED. SPRAYED WITH OIL. ALL GOOD NOW.. WHY ARE THEY GETTING CORRODED IN A SEALED TAIL LIGHT?
Rado
US NAVY VETERAN
Maine
Pentastar 3.6 V6
Interesting ! Good post .
I am no help but a wild guess is the O ring still on the light socket ?
Were they tight ?
If you do find out why please Update!
KWal
DFW
V8
I have an '05 & an '06 that both had issues with taillights blowing bulbs consistently.
Would find moisture inside them on an almost daily basis.
We wound up replacing all four assemblies with OEM. It wasn't cheap, but it fixed the problem.
Good luck.
tron67j
Maryland
I had similar problem in my 2003 2509, I ordered replacement sockets and installed them on both sides. Think I ordered on Amazon or eBay, but can't remember.
laserz230
Whitney, TX
V6
I own a 2022 Ram 1500 Bighorn. Both tail lights are out. Checked fuse and replaced bulbs - no change. Front park lights are fine. No indication of a problem on the dashboard which I find alarming since the rear of my vehicle is totally blacked out at night with only the license plate light illuminating. Years ago, when you lost tail lights at least your dash board lights went out also to indicate something was wrong. I only found out at night when a county sheriff pulled me over. Any solutions before it goes in to the dealer for troubleshooting?
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
Tail Lights have always been a mystery to me !!
Some times, there are only 2 bulbs with 2 filaments in each one
each bulb & harness has to do
tail light
brake light
turn signal
flasher
with the license plate light(s) tossed in
Then you have 3 bulbs per tail light, which added back up lights
The harness on the drivers side, added lights for the camper shell ..
interior light & 3rd brake light, & camera(s)
Bed Lights & power receptacle
No wonder they completely seal the tail lights up now
Plus Stellantis does not want anyone but their Dealerships to work on products they make, GREEDY MFers
they deleted all the do it yourself publications that Chrysler & FCA had put online for us to work on our own vehicles
