Tires
drtumolo
I am looking for the unicorn of tires. I want a load range E that is excellent in snow/ice, good highway durability, rides good and is quite. Right now I am on a set of Cooper's and they are good for everything except snow. NEED Advice.
tron67j
Maryland
I second the above, snow or ice grip comes at the expense of quiet. Could consider a set of steel rims with snows and have your quieter tires on main rims. I have done that, makes a nicer ride for 10 months of the year.
D
drtumolo
I am looking at Falken wildpeak AT3W, At4W and BF Goodrich KO2 & KO3 tires so far. I have heard good things about all of them.
Pudge
Alberta, Canada
2021 Power Wagon 75th
The Wildpeak At3W edges out the At4W as it relates to snow and road noise. If you do a lot of off road, then the 4 is better. My At3Ws are quiet.
D
drtumolo
I do virtually no off roading. I tow a camper during the summer months so that is also important.
Scottly
Safety Harbor, FL
HO 6.7 Cummins
I run Ridge Grapplers. Trust this Florida boy when i say they suck in the rain. We get plenty of it.
Pudge
Alberta, Canada
Yep, like me. At3Ws! I’ve got 40,000kms (25,000 miles) on mine and lots of tread left. I pull an RV trailer in the summer too. I run 40 psi in the back and 45 psi in the front when I’m not pulling the trailer, I rotate my tires often, and I’m really happy with them. I’ll be buying them again when the time comes.
Papa Red
Papa Red
Nebo, NC.
I just got the Falken Wildpeak AT4W tires on my truck. I purchased them based on the reviews. Just a slight road noise over the factory tires. They look like they would be awesome in any conditions.
Red
Tom Davis
Colonial Beach, VA
5.7L
I run the Falkens on my truck. My experience is they are loader than I would like, but they excel in everything else so I can live with it. Prior to these I had Toyo Open Country AT2s and they were the worst tire I have ever driven on wet roads, the Falkens are much better in everyway, except noise.
D
drtumolo
Pudge, how do they do in snow. My 2500 is the worst vehicle I ever owned in the snow.
D
drtumolo
Ok I will probably go with them based on the ratings I am seeing. Do they do ok when towing and how is the noise level?
NotSoFast
Flagstaff
6.7 liter diesel
I mostly love my Cooper Discoverer AT3s. They are quieter than the OEM tires, & WAY better in snow. As a 10-ply tire, they are very resistant to sway. That's real important for my situation, because I use my 2500 diesel for towing more than not. But they won't qualify for the OP's unicorn status, at least the way I run them. I keep them inflated pretty hard because over half of the time I am towing. So they transmit potholes and ruts. They are pretty good on washboard, but I only tow slowly on washboard to avoid beating up the trailer too bad.
D
drtumolo
The Cooper Discover AT3 is what I currently have on my truck but I dont like there snow traction. Good when new but dropped off quickly as the tires got worn. I just ordered the Falcon AT3W tires and hopefully have better luck with them.
texcwa
Jackson, CA
6.7L HO
I agree with others, I tow a 16k fifth wheel over several summit passes several times a year and drive my truck as a daily the rest of the time. I only run Cooper Discoverer AT3 xlt due to their load rating, quite ride, great mileage and have had no issues in the snow (compared to other tires I have used in the past).
chaosh1
I use the Falken wildpeak AT3 on all my trucks. 3-peak rated and does very well
Toddbigboytruck
Ontario
Living in Canada, I looked at the KO twos but I settled Cooper Tires - Discoverer AT3 XLT they are true 4 season tires I got 80 000 km on the last pair now I am on the second pair , almost no road noise and are good in mud and hiway.
