Who else had a hard time getting 4 digit pin from dealers?
R
ramtruckrob
Virginia
Just know that alfaobd requires a one time fee for the license and it's $50. Well worth it in my opinion.
diymirage
Here's a strange on for you guys
I pulled the pin from my truck no problem
I did some changes to my 15 charger, and now when I try to pull the pin (or reset the rf hub) I get a no go message
R
ramtruckrob
Virginia
Not saying this is what you did, but I've forgotten to connect to the hub before starting the procedure since you have to connect to the OBD and then connect to what ever computer you are working on separately. I've even forgotten to connect to the OBD and wondered why I couldn't do anything.
diymirage
No sir, I checked that, because you're right, it's easy to overlook
But that was not the issue
(To prove that, I went into the rf hub and tried one or two "test", locking the doors through alfa obd, that worked fine)
RamDiver
Marlborough, Ontario, Canada
Woh... The MX+ has gone up $70 since I bought mine 5 months ago. I paid $140 and now it's $209 on amazon
Are you certain that you didn't accidentally look at the dot ca site?
I see $140 US on dot com and $209 CDN on dot ca.
Welcome to the feeling of being screwed by amazon for being a Canadian. :cool:
04fxdwgi
Coastal NE North Carolina
2016 1500 Sport
Ok, that may have been it.
Ram1958
Carstairs AB
That's what I used. Reprogrammed 2 new fobs in less than 2 minutes. Dealer wanted $400 for the fob, key blank, and programming and cutting the key. Bought AlfaOBD and the odb cable. Worked like a charm. Also turned off the damn seat belt reminder ding. Total cost was about $100 and can do so much more than just the fobs
AlfaOBD - https://www.alfaobd.com/
Cable - https://www.amazon.com/gp/product/B005ZWM0R4/ref=ppx_yo_dt_b_asin_title_o06_s00?ie=UTF8&psc=1
Will this also change light settings. Change DRL from low beam or high to signal lights?
aszumilo
Las Vegas
Not sure. Didn't mess with it too much. Just changed programmed the key fobs, turned off seat belt chime, and enabled the back up camera I installed.
04fxdwgi
2016 1500 Sport
I set / added the DRL's to my turn signals and put the on/off control on my 8.4 screen. Being in USA, my DRL's weren't activated at all. In CA, yours are.
You can download the AlfaOBD and use it in demo mode (won't connect to vehicle) without purchasing. Then you can see 1st hand all the stuff it'll do.
RamDiver
Could you please describe how you're able to switch the 8.4 screen on/off and where this setting is located in AlfaOBD? :cool:
I understand that there's settings somewhere for law enforcement vehicles that allows disabling of all interior and exterior lighting. Do you have any idea of where to find these settings?
04fxdwgi
2016 1500 Sport
As for the turning off the 8.4 screen, If you have the 8.4" unit it has a "Screen Off" button right below the screen to the left of the Hazard Warning button. It's a button on the center stack, not in AlfaOBD / BCM.
Post you referred to was talking about adding the DRL's on / off switch to the 8.4 screen. As far as the DRL's are concerned:
CBC Features: DRL Dropout Enabled
Select “yes”
ECU 3: DRL Customer Setting Enable/Disable
Select “yes”
Customer Service Menus: Daytime Running Lights CSM
Select “yes”
RamDiver
I seem to have forgotten about that screen-off button, thanks. I look forward to testing that function during my next road trip.
Select “yes”
Select “yes”
Select “yes”
Thanks for those details.
diymirage
you may need a dedicated dimmer switch for that, ill have to check the wifes winter beater when she gets home
at any rate, it is found under "car configuration change"
"vehconfig 3: police lighting feature"
now, i will tell you why i hate that setting
with it turned on, a set of safety features automatically get activated
the most annoying of which is a deactivation of the automatic rear door unlocks
you can still unlock them by hitting the unlock button, but if you put the vehicle in park, shut off the engine and open the front door, the rear doors will remain locked
great for transporting prisoners, a pain in the rear for running kids to soccer practice
RamDiver
Thanks for the information.
I'll have to identify a workaround for that safety feature before adjusting that setting. Manually unlocking the rear doors sounds like too much of a PITA just to have no lights for the odd occasion.
