Rick Ram-jet
- Joined
- Feb 8, 2018
- Posts
- 215
- Reaction score
- 194
- Location
- Big Bear Lake Ca
- Ram Year
- 2016 2500 4x4 CC / LB
- Engine
- 6.4 L
Ok, after doing more research I found that Carli offers a heavier rate CS-DMRC-14-R2 rear spring that will ride better than stock but sit about 1in higher than my current Thuren springs giving me a slight forward rake. That should give me a lot less squat and combined with a Weigh Safe heavy weight distribution hitch (currently under re-design and avail in a couple months) and added support from my 5k air bags if needed. I`m currently checking to see if I can still use my same Thuren/King rear shocks with the Carli springs for now.
I think I`m making good progress on selecting the needed upgrades to tow my upcoming new/heavier toy-hauler...
BTW, Thuren also makes a taller/higher rated rear spring but they suggested going with the stiffer Carli spring for my intended use...
