UpstateNY2012
Hi all,
I just went outside to pick up my little guy from school and my truck wouldn't start. No power at all when I opened the door and inserted the key. Nothing. I figured I must have left something on when I and drained the battery. Grabbed a jumper pack and still nothing. Pulled the battery terminals cleaned them off and reconnected. When I got back in the truck I saw a solid red dot on the dashboard that went away for a minute or two. A quick GOOGLE search showed that this is the ant-theft system indicator. I've been searching the internet for a solution but I'm having no luck with anything. I was hoping someone here might be able to help. (Cross-posted from Electronics to get more visibility.)
Thanks!
Update:
I pulled the battery and found some moisture underneath where that bolt is. It looks rusted so this can be the first time it's gotten wet. Also a space next to the battery had a small amount of water. We did get rain all day yesterday. I've attached the pics for reference.
Edit:
2012 ram 1500 5.7 4x4
Thanks!
Update:
Edit:
