2020 RAM limited suspension
Drakemparker
Prairieville
5.7 Etorque
My air lift suspension won’t lower or raise. Says it can’t until my side steps are retracted. But when I’m at a stop. I go to the menu. Hit deploy steps, and then retract steps and my steps do both fine. But truck still says can’t lift or lower because steps are deployed. Any ideas?
KKBB
Oakland Ia
I have no ideas...my wife has a 2022 limited that has been good so far, so sorry...I am of no help.
DanAR
Arkansas
In old tech it sounds like a limit switch malfunction. In today’s world of computer everything it’s probably a processor. I think you’re going to have to visit a dealer with hopefully a computer tech-savvy technician.
Mpgrimm2
Preferred Vendor
SC
2022 Ram 1500 (5th Gen)
5.7L
Haven't had that issue with mine either but here's a diagram...
brian42
San Diego, CA
I agree with DanAR, it sounds like a limit switch issue. Either it's sticking or has a bad connection (possibly bad connector/connection/pin or chafed/broken wire).
If you can find the switch I recommend spraying it with some lubricant to see if that helps. Many use a lithium-based spray but I had the best success with bicycle chain lube as that dries without attracting dirt.
darioa
Louisville, CO
Diesel 3.0 L
I had trouble with my suspension 2023 RAM 1500 Limited) and I had to do a reset of the suspension, which fixed the problem of not being able to raise it or lower it. I can’t remember the steps but you can search how to reset it. Just pressing a few buttons on the console, so it is easy to do.
