Gearing for towing
ramcummins17
new jersey
6.7 cummins
I have a 2017 2500 tradesman. I was wondering if there was a better gear for a little more acceleration while towing. I believe I have 3.42 gears and I don't know if it's just me but I feel like the truck struggles a little to much from a light with a 10k max trailer. Trailer and cargo is about 9k altogether. If I'm thinking to much about it let me know so I can feel better haha, thanks.
2003F350
6.7 CTD
3.42's would be fine with a 6.7 CTD. A little on the tall side if you are towing a lot, but nothing that will be hurt by 10k.
I've got 3.73's in mine, but I wouldn't recommend spending the money to change unless there was something physically wrong with yours (broken/worn gears, etc).
Basically, unless you're looking to burn some cash, I wouldn't worry about it.
BossHogg
Oakland Township, Michigan
6.7L Cummins
3.42's are fine for your setup. Can get pricey to change if 4wd as you need to do both diff's.
He is right, I have a SO 2015 3500 HD and pull a Montana fiver that weighs in at 16K. I have zero complaints and can effortlessly reach 65 MPH on a freeway acceleration ramp.
nlambert182
Huntsville, AL
I had 3.73s in my 12, 4.10s in my 16, and 3.42s in my current 18. Trust me.... at 10k lbs, you won't notice much of a difference between 3.42s and 3.73s. 4.10s make a big difference but are completely unnecessary until you start getting into weights that are more than your truck can tow anyhow.
Understand that a Cummins with any gearing isn't going to win any races from a stoplight. They're not designed for that. But my 2500 has no problem keeping up in traffic even when towing my travel trailer, which is about 9,800 lbs loaded.
