ram
  1. Z
    2004 Ram 1500 4wd transmission problem
    Hello, so i am scratching my head at this problem I was driving about 45 miles per hour and then my RPMS shot up to 6k and i have no gears, i tried 1 and 2 manually and nothing, i was able to tow it home. One thing i noticed was an odd whirrring sound coming from underneath but no leaks I...
  2. BigBo956
    ABS service electronic system lights
    I have a 2018 ram1500, 2wd, harvest edition, 49k miles. The ABS light came on and said to service my electronic braking system, shortly after I heard a bang, boom, pop, the wheel was completely sheared off, and all that I saw were bearings all over the road. Any idea what the heck happened...
  3. Elik14
    Upgrade Sound system
    2014 ram 1500 looking for a sound system upgrade around 300-500 I don’t know if that is a low budget not trying to break the bank that’s not there but any recommendations would be appreciated.
  4. Elik14
    Pioneer Audio speaker
    2014 Ram 1500 I was wondering is I could use pioneer ts-g1047 speakers as tweeters since I just have em laying around or is there a better alternative open for any suggestions.
  5. Elik14
    3.21 gears to 3.92 2014 ram 1500
    On moes website I see that the trutrac has option for the master install kit. would I have to chose that option if I’m going for these gears. https://www.moes-performance.com/Motive_3_92_Gears_for_9_25_and_9_25ZF_Rear_p/c9.25-392.htm?CartID=1 Or would I have to use this master kit instead...
  6. SouthernGent1500
    GOOD OR BAD? FLORIDA Service department at DODGE dealership vs general mechanic
    I have not been having a good experience at any of the Dodge SERVICE DEPT at any of dealerships in Central Florida. Curious if there’s anyone who could recommend the best service department near Central Florida? Or is it in Tampa or Lakeland? Really want to leave my truck in the right hands...
  7. ConorToot
    Steering Angle Sensor Readings on AlfaOBD
    My brother-in-law and I were looking at my 2012 RAM 1500 SLT 4.7L FlexFuel RWD initially because I have a C121E fault that has plagued me for over a year now, but he noticed something when I had AlfaOBD on the graphing function. He was looking at the readings that I get from the steering angle...
  8. M
    Tow haul/traction control/ heated seat/ heater steering button not working
    I have a ram 1500 classic. I just noticed my Tow haul/traction control/ heated seat/ heater steering buttons are not working. Heated seats and heated steering can be turned on from the screen through apps but buttons are not working. Moreover, my 2wd 4wd and neutral buttons don’t have power...
  9. 4
    Mystery Button under dash
    Hey everyone, I recently bought a 2017 Laramie 1500 4x4. The other day I was vacuuming my floor mats and saw an aftermarket button/controller had been installed by a previous owner. There is no label on it and I have no idea what it does. My initial thought was it belongs to an aftermarket...
  10. Bmags
    Exhaust Drone Fixed! Spoiler Alert another 3.21 vs 3.92 discussion
    Just figured I’d throw this out there to the group. BACKGROUND: There are many reasons why folks love the 3.92 gears… (way lower 1st gear, lower reverse gear, better acceleration, etc) but for me I mainly was searching for ways to remove my highway drone from my Carven Competitor (which I...
  11. Bmags
    MDS Delete SOLVED
    Just wanted to share this, pulled the trigger and had my ECU tuned to delete the MDS from functioning. Super simple, mailed my PCM out and he mailed it back with no more MDS!!! The guy said if sending in my current PCM wasn't an option, that sourcing a used one could work too. Can't believe I...
  12. ZCarramrod1
    2016 1500 hvac (Bighorn)
    lost cold A/C determined it to be the evaporator tried to replace the refrigerant (yf-1234) first myself and it didnt work found dye-color refrigerant leaking from the A/C-condenser at the front. Thought: "great now I don't need these actuators, evap and heater core or these aluminum blend...
  13. S
    Can i swap a 2004 NON MDS HEMI into my 2007 HEMI?
    Motor recently went Kapoot in my 07 dodge ram I have a line on a 2004 motor but I know that they did not have MDS will this cause a problem with the swap or will I just need a tune afterwards I know you can put a 07 into a 04 but does it work vice versa? What all will I need for this swap or am...
  14. T
    1st Gen Royal SE
    Hey Y'all, I recently inherited this 1986 Dodge Royal SE 150 from my grandfather and was wondering if anyone knows if there is a market for it. It currently has 84k miles and is in entirely original condition, runs better than ever. Best, Alexander
  15. Leede
    Any Thanksgiving giveaway act?
    I saw the Thanksgiving giveaway offered by Hooke Road and I entered, hoping I could win! Recommended to everyone!
  16. S
    Security
    Security system doesn't recognize driver and passenger rear windows being broke. Theaves broke the glass and climbed in through the passenger side rear window without the "Security system" activating. Any recommendations on a good Security System for Ram trucks? 2022 Ram 2500 Bighorn edition.
  17. H
    Identify Part? 2005 RAM 1500 Grille / Radiator "Clip"
    Pic attached Friend asked if I could find this part for them. They are repairing/replacing a grille. Perhaps a Radiator. They called it a 2005 RAM 1500 "Grille Clip" Obviously not a "clip" I've not had any luck. Stud? Can anyone identify the part? part#? Thanks
  18. T
    Help with steering shake
    Hi guys, this is a question of what i need to do next to resolve this ongoing problem. my 2011 ram 1500 4.7l 4wd quad cab 6.5ft bed had some suspension work done around the middle of march and i have been fighting the problem since the suspension was redone. at around 65-75MPH the steering wheel...
  19. FiverPuller
    Things that make you go hmmmm!!!
    2019 Ram 3500 purchased new December 2019 it has run flawlessly for 46,000 plus miles pulling my 40' fifth wheel. Not once has the "Regeneration in Progress" come on. Fast forward to last month when I took it in for the HPFP (high pressure fuel pump) Recall. After installing the previous...
  20. F
    new after market true LED headlights not fully working
    Hey, new to the site. Hopefully someone can aim me in the right direction. 2018 ram 1500 5.7 express DNA Motoring LED headlights. Right, I bought some true led headlights (full housing assembly) to replace my deer smashed headlights (LED is replacing halogen NON projector) The headlights...
  21. L
    2013+ cummins dash in 2011
    Hey folks, I have a 2011 SLT that I would really like to have the newer cluster and 8.4 uconnect in. Is it possible to buy a complete dash and swap it in? Would the newer TIPM have to be installed aswell? Basically trying to see where it could be adapted in at, or what all will have to be...
  22. M
    Identifying Rear End Differential
    Have a 1994 Ram 2500 W/12 Valve in it. It needs a new rear end, which I'm pretty sure calls for a Dana 60, but I'm not entirely sure. It has a 3.54 gear ratio and ten bolts on the punkin cover.
  23. nevinwright43
    Glow Plugs and Electric Vacuum Pump
    So, some background information: 2015 Ram 1500 Ecodiesel 3.0, DEF deleted. I bought it used with 220k (140k miles) on it. Recently, I had a diesel shop replace my engine timing cover (due to it leaking). After the replacement I drove it about 130km and my fuel injector line burst and sprayed...
  24. SugaryClapz
    My front windows are not working
    Couple days ago I hopped in my truck and tried to roll my front windows down and they are not working all of a sudden. My mirror adjuster and locks won’t work either, but rear windows roll down. Any help would be appreciated!
  25. E
    2004 1500 Hemi misfires and dies at idle?
    Just purchased a 2004 ram 1500 5.7 and the owner told me about this issue. Got it for a low price cause of this reason. When i start it up and let it sit at idle it throws the rpm’s up and down a bit then misfires around 600 for a little bit then dies. If I keep its rpm’s above 1200 it runs with...
