14 Hemi 5.7 Cooling Issues
McGeezy83
Maryland
So just to set this all up, I have searched through most threads about this issue and only one really had feedback about a solution. Hoping I'll jog someones memory to find a solution.
My truck has normally run with a coolant temp of about 220. I had my water pump, upper and lower hoses, and t-stat replaced in january. This week when taking my son to high school in the morning my temps started to climb to about 230 and then back down to 215-220. Well today I got on the highway to go down to UVA (I live halfway between DC and Baltimore) and the temps jumped to 245. Pulled over, turn off the engine. After 15ish minutes I'm back down to 220. Head down the highway, 5 min later back up around 240.
Flushed the system today, replaced with correct coolant. Take it for a ride in the back roads (40mph tops) back up to 240. Get home and back on the ramps. Try to burp the system (reving at 2k with the cap off) I overflow the rad.
I know the t-stats can go bad on a whim. Does this sound like a stuck stat to you all? The fans are running, again water pump/ t-stat was replaced in january (10 month run time). I'm tempted to just go buy a new stat and replace to see what happens.
Thanks for everyones help!
rzr6-4
nebraska
Thermostat is probly the easiest fix, and a fairly cheap one at that. If you get a new one, test it in boiling water before installing.
M
McGeezy83
Maryland
Rzr6-4, really test before you put it in? Interesting
Indept, I thought about that too. At startup they are open. Moved with my hand and the actuator closes so I think it's still good.
Update: top hose is hot, bottom hose is warm. Seems like I have flow but maybe not good flow. Maybe there is bad flow through the radiator. I don't have the tools to test. Starting to question the radiator.
These days the odds of getting a good thermostat are questionable.I've had more bad new thermostats then good lately.Throw it in a pot of water and use a meat themometer to monitor the temp where you're new thermostat starts to open,as the water gets hot
04fxdwgi
Coastal NE North Carolina
2016 1500 Sport
Also, try getting a hold of a digital laser temperature meter and verify the temp at the sender is same as digital. The temp sender may be on it's way out, too, giving a false reading.
MRFREEZE57
pacific northwest
I removed my grill shutters the other day, just left the upper and lower ones. Was getting temp spikes up to 220 deg going up hill before, now temp is stable between 198-204 deg, no spikes when under heavy loads. were staying closed even when up to temp.
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
You can BURP the cooling system, with the engine Cold !!
There are 2 places that you can do it from, both places are the highest points in the system
This guy really knows his Rams
#1 is the preferred method
#2 ) is the Optional Method
El Guapo Phil
Belize, Central America
From another of my post,
I want to add my 2 cents to the thread. I had to replace my radiator a few months back. Installed a 180 stat to see how the Ram would run. All seemed good to me. The medium term was about 195. I thought all was good. Then the motor began to get hotter on longer hilly trips in Belize. On a trip to the coast, the temp would climb to 235. There had to be something wrong.
Decided to get a new stat in the morning after returning, all the while nursing the Ram on the 2 hr drive. Checked the radiator reservoir, it was full. Pop the radiator cap and had a feeling the radiator need bit more coolant. I had to add ¾ gallon. Yes, that much.
I realized the shop that installed the radiator and did the bleeding did not know about the Ram needed to be in an incline to properly bleed the air out of the system. It took time for the Ram to finally get enough to the air out and me checking the coolant in the radiator, not only the reservoir, to solve the heating up problem...very low on coolant.
Test drove the Ram while checking the radiator temperature, it read 180 to 188 while going up and down hills. Put it 4x4 and when up a steep drive. Stat read 190. The panic I had the last few days is all gone.
I learned to double check whatever the mechanic shop did if it is at all possible.
Daw14
That last sentence is some very good advice that everyone should follow.
