AbeTabe
So my abs light and traction control light came on, at the same time my right front brake tried to lock up and was stuck grinding, it appears something happened in that wheel bearing by all the shredded metal around it and it was cockeyed, the axel/ wheel bearing/ something happened, my brake rotor was completely miss aligned and grinding all over the caliper. let me rewind a month ago.....
my truck won't engage 4th 5th or 6th.... in auto it gets to 4th and just revs like its in neutral, same as 5th 6th. It shifted just find 1-3 for over a thousand miles no problem, I had to set it to 3rd gear manually so it wouldn't shift into fourth, therefore not basically going into neutral, as soon as it would do that it would not downshift to 3rd without turning off and turning the truck back on. I replaced all the sensors to no avail. Now I can't drive the piece of crap at all. the truck ran great until I hit 50k I had a minor problem. Now at 140k everything is just going downhill fast. It's probable not even worth fixing at this point.
Some other weird thing that really pissed off my neighbor hood I lived in a couple years ago was my ALARM going off randomly all the time. And the truck constantly locking and ulocking....
Even weirder I had someone bust one of my windows out and the alarm never went off, also someone try with a rock 4 times leaving permanent scratches and the alarm did not go off. My self personally prying the door open when I locked myself out 3 times, alarm never went off on this thing. Just randomly at 2 am overnight, everyday. I used to say great things about ram but I think these trucks are programmed to go out at certain times.
Ive done a lot of research and it just seems all these SENSORS are cauisign ALL THESE PROBLEMS!
GET RID OF THE SENSORS!
