2017 Ram 2500 Tradesman Blend Doors
rkdub
Colorado
Just bought this a month ago. When I bought it there was a little creek behind the dash, didn't think too much of it. Over the last month, it has turned into a loud creaking noise that cycles a bunch on startup and finally settles somewhere. Of course, if I change when air is pushing, it creeks again. Going from left to right facing the dash there are four blend door actuators. I've replaced #1 and #4. I cannot remember primarily when the creaking occurred, and now that I've replaced those two, the creaking is gone. The creek was definitely, primarily, #1.
Now, and this changes, but this is where I'm out now, I get consistent air from the floor and the vent, but the vent doesn't always turn off, and I can't get much out of the defrost. On another post, I saw a removed HVAC assembly with pointers to the different actuators and what they control. But not for my year/make/model.
Does anyone have a good breakout of #1-#4, what they control? Also, calibration....? I tried pushing the air recirculator for 10, letting go, and pushing again, guess this is for older models. I'm concerned that this is going to require taking it in and paying a bunch of money for someone to hook it up to a machine and push a button. Is there another way to recalibrate? Disconnect battery? Gear line up? Something?
I don't have auto or dual climate control. Nothing fancy. I don't have trailer brake control on mine, but this is essentially what the dash looks like.
Much appreciated in advance.
there are 4 Actuators, which consist of an electric motor & gears
up by the top right corner of the glove box, there is a Circulation Door & actuator
Behind the lower left corner of the lower glove compartment door, you can see the MODE door & actuator. That door in 1 position runs the air flow over the heater.
In the other position, it runs the air over the condenser.
The next 2 actuators, are located behind the Brake Controller & aux. switch panel
Each Actuator is held on by 2 screws & attached to wiring
In this video, they pull the Blend Door Actuator
Then she takes it apart, when she looked at those teeth, she would have found broken teeth, you can often lift the wheel off & rotate the wheel 180 degrees & put it back together.
At that point, you can plug it back in, without putting the screws back in, if there is no more clicking, the actuator will often work for months or even years.
Another thing, before the actuator is mounted again, you will notice a white fitting that the actuator fits on to ,,, take your fingers & try moving that fitting, just a 1/2 rotation left & right, without much force.
IF you feel some weight & hear a slight THUD, that means that the door is pivoting correctly. Then carefully re-attach the actuator.
Every actuator is the same as the other actuator
Mopar Actuators are the best, because they are strong & self calibrating, maybe $30 each
R
rkdub
Colorado
OK, the creaking came back. Like a big dummy I think I was messing around so much to get the "alignment" right, I put the old one (that wasn't quite broken yet" back in. Anyway, getting ready to go back in there and swap it out with a new one. I saw on a post that there are two dashes that line up to show center. In the video you recommended, she doesn't do anything to either the lever or the actuator. Just leaves the lever down and puts it in. I have two brand new ones (they're so cheap I ordered 4), you're telling me if I just let the lever hang, and install the new one as is, the truck will auto calibrate to center and everything will work fine? If so, that would be just fantastic. That's not what the videos out there are telling me, but it makes sense, the way I can hear the actuator go back and forth (creaking) every time I start up. Sounds like it's looking for it's endpoints and setting center.
Thanks again.
etdavenport
Kenai, Alaska
6.4, 5.9 Magnum
I'm having a similar problem. I have heat on the right side, but not the driver's side. I live in AK and would really like everything working.
My blend door behind the glove box is fine. Where can i find a parts diagram for rest of the actuators. And which one is likly to be the problem?
2017 Ram 2500 Bighorm.
aszumilo
Las Vegas
Do you have air flow on the driver's side? If the air flow is good, but, no heat, it could be the heater core is plugged up. The way it sits, the top half goes to the passenger side and the lower side is for the driver's side. If it is plugged up, sediment has probably settled to the bottom of the core and not letting the water circulate through it properly.
I miss stated actuator positions above ...
I wrote Mode Door, it should be Blend Door is the actuator & door is found by removing the lower glove box door, then look just to the left of the blower
Blend Door is the door that directs the air flow either for heat or to cold air
This top image , i believe is for MEGA CABS & Vans
Most of our Rams only have 1 temperature Actuator, located where it reads Left Temperature Actuator
Ram HVAC Units are basically the same in the years 2009 - 2018 & possibly newer
It is likely that there are 50 or more YouTube videos on trouble shooting Ram HVAC Systems
I will not include the Gen 5 Ram , ( new Body Style )
only because i personally don't know anything about them
Guess What ??
I found a video about the HVAC system
That i had never seen or heard anyone mention !!
AC Acting Funny
Humidity Sensor ??
rkdub ...
You will learn that the OEM Actuators are the best
The OEM Actuators have LIMIT Switches
They also have the ability to be reset, using the Software
aftermarket actuators don't have that ability
