2018 3500 Dually side marker lights and under tailgate light out
crow5716
Ohio
So the other day all 4 drw side marker lights are out and the oem little light strip under my tailgate is out.
I still have roof top clearance lights as I believe those are on the same circuit so it's not a fuse.
From the one diagram I was able to find it looks like a white wire with green tracer that feeds those but apart from pulling the whole harness along the frame that's over the fuel tank and def tank I have no idea where to start.
There are no wires or harnesses pinched between the dually leafs and bumpers like I've read about. But all signs lead to a break feeding the rear.
I just want to make sure for some reason that the rear marker lights aren't fed through the abs harness, which is a weird statement, but I just had a problem with a rear abs sensor and it ended up being the wire was broke along the way somewhere so I just spliced into 2 new wires from the abs harness back to the where the abs sensor plugs into and have had no problems with it since. I was getting the dreaded service abs light which disables 4x4 but the only code I was getting was left rear wheel speed sensor out of range. So after that fix, that night I noticed my rear marker lights were out. Which is why I wanted to make sure those lights didn't get their power from that abs harness. lol.
But any help would be appreciated on where to start checking. If someone knows where the two harnesses pictured 3/3 and 6/6 are or had any other suggestions.
Truck is 2018 Ram 3500 DRW 4x4
Thanks in advance for any help.
clifford15
CTD
Check for a stray wire captured in the overload springs on both sides.
It was a problem on earlier versions.
C
crow5716
Ohio
I did check that. Plus I also included that in my original post that there were no wires pinched from leaf springs.
C
crow5716
Ohio
Still haven't figure this out yet. I tested the plug on one of the dually clearance lights and was getting ground on both terminals. My last resort is to splice in power from the tail lights but I need to make sure I sever the connection going back towards the front incase it is shorted out or broken somewhere that I'm not sending power back that way. I had a problem with a wheel speed sensor that I ended up rerouting that is also in that big harness bundle going back. There has to be a break in the wire somewhere along the frame rail but it's a big bundle of wires all wrapped and impossible to get to in some areas because it goes behind def tank and over fuel tank. From the few vague schematics I found online I can tell it's a white/green wire, but I've check a few places and see multiple white/green wires. Any help would be greatly appreciated.
EDIT: Additionally when this first started happening I could wiggle the wires around near the abs harness and the clearance lights that are out would flicker or work for a bit.
C
crow5716
Ohio
Can anyone suggest a different ram forum that may be more helpful or helpful at all?
RamDiver
Marlborough, Ontario, Canada
Wiggling miscellaneous wires and obtaining a flicker or intermittent performance of the troubled lights sounds very much like either a bad ground or flakey wiring harness.
The best I can locate for a service manual is a 2012-2017 compliments of Dilligaf.
It might be worth reviewing to locate common grounds, wiring harness routes and confirming if your problem lights do share a fuse or wiring with other devices.
