2018 ram 1500 overhead mics after dash harness upgrade from a 2016 ram 1500
MeleeGaming
Lower Nicola, British Columbia, Canada
Pentastar 3.6L V6
Hello I recently went through the hastle of changing out the entire dash harness in my truck to accommodate a radio upgrade from the uconnect 5.0 to 8.4 and unlock a few other features later on. My truck is a 2018 ram 1500 slt crew cab. The dash wire harness I swapped in is from a 2016 year range laramie truck so there are a few differences most of which ive got figured out and solved aside from 1. So far everything works aside from the overhead microphones now. My truck came with Bluetooth overhead mics from factory so its already wired and pinned from the mics down the a pillar to the green connector behind the drivers side panel.
My question is what do I need to do to get the mics working from the 8.4 (which is out of a 2015 truck). I noticed that there are a few pins missing from the dash harness side of things that is on my trucks side of the connector but not sure how the wiring works for the 2016 year range because I know they used to have the mic in the rear view mirror.
If there are any pictures required for anyone to help me out let me know. Greatly appreciated!
ric221
I really can't help with your issue. But I'm a little confused. Why you started with a 18. down graded wiring from a 16, added a radio from a 15 just to upgrade your radio to the 8.4. Why did you not just upgrade to the 8.4 radio from a 18 model year? I don't believe you would be having this issue had you gone that route.
