Hey ya'll this is my first post and super happy to have found the community. Bought a 2023 RAM (engine specs in title) and towed my new 2022 Grand Design MK200 travel trailer from TX to GA about ~1,000 miles. I've read some of the posts here and I've found what you guys have said to be extremely accurate, specifically the part about with a 3.21 rear axle ratio in the 1500 how it is most efficient at towing speeds 48-57 MPH. I set my cruise control at 57 MPH on all flat dry roads, could hit 60 MPH on a downhill, and had to back it down to either 54 MPH, 52 MPH, or 50 MPH on all hill climbs depending on steepness of the grade. As others have said here I'm just a little uncomfortable with 57 MPH being my top highway speed pulling this 6,500 lb trailer. Lots of highways with 70 MPH limits and I'm in the far right lane (or sometimes one lane with a line of unhappy people behind me) going 50 crawling up the moderately gentle hills coming into GA. I feel I'd never have a chance at ever taking the trailer to Colorado, Oregon, or even North Carolina where the hills will only get more aggressive. I mean, what would i do crawl up more agressive hills at 35/40 MPH in 70 MPH speed limits? Just feels like I need a bit more power here.
Basically reading that the 3.92 rear axle ratio is more efficient at 58-70 MPH which sounds awesome to be able to maintain 65 MPH and have the truck feeling happy to do so and maintain it. So thinking about just swapping trucks to get the 3.92 rear axle ratio in hopes of maintaining 65 MPH highway speeds. Also read I will lose a little mpg but that's ok. Only other option I'm considering is going for the diesel, but I see most have tow capacity of around 9,600 lbs in the 3.92 rear axle ratio. That's not much more tow capacity than I have right now at 8,200 lbs. If I stick to regular gas and go for the 3.92 I get 11,200 tow capacity.
I'm pretty close to just going out and swapping for my exact same Ram truck (2023 5.7L V8 HEMI MDS VVT eTorque Engine) but just doing a 3.92 rear axle instead of the current 3.21. Anything I'm missing here or fairly spot on? ** FYI I know I could push my current 3.21 past 57 MPH it just felt like 57 MPH was it's happy zone to maintain on flat roads. Anytime I pushed past that, it did it, it just felt like I was asking a bit too much from the vehicle. Any thoughts appreciated and thanks form a first time Ram owner!
