98_ram
- Feb 20, 2014
- 3
- 0
- 1998
- 5.2
I've been thinking about swapping in the 3rd gen 5.7 into my 2nd gen. All the threads I have read through are basically just before and after pictures and video and are not real informative on the actual swap. I am fully aware there will need to be rewiring done, that doesn't bother me at all. I have done over 20 swaps from 4 cylinders to big blocks with my first dating back to when I was 16, I'm 25 now. With that said I would say I'm pretty set mechanically and experience wise.
I'm mainly looking for info as to if it is a direct bolt in or if not which mounts I would need to use from either generation. Also if anyone has a pinout for the 3rd gen pcm/ecm/ecu as well as the 2nd gen. I plan on using the 3rd gen harness so I am not screwing around with plugs and whatnot and plan to wire my 2nd gen cab harness inline with the 3rd gen harness. And then later on throwing in a 3rd gen cluster as well. That's after everything is done though, my primary focus is getting it swapped in and I can figure out the wiring on my own.
Questions, comments, concerns, advice.. lets hear it! I need to get this build rollin!
*And on a side note, if you're interested in making extra money for your own build click the link in my sig. That is what is funding this project haha no joke. DO NOT comment on this thread about it though because it would be counterproductive to what I am trying to get figured out for myself, rather, PM me if you have questions about it*
