4.7 engine 2002 ram 1500
Yungogwaffle
Charleston sc
I have a 2002 ram 1500 with pcm having 3 connections I’m trying to see what type of dodge with a 4.7 will fit it other than the 2002. Basically I’m trying to see if a 2000 or 01 of a dodge truck with the same 3 connector pcm will fit also having a 4.7?
jws123
nj
yes it would fit also use a jeep 4.7 same years I think late 03 is when they changed to 4 connectors and a diffrent tone ring. You could also if you wanted to get a newer 4.7 swap the tone ring on the crank from your old engine but thats alot of work also you would need your old timing chains. I have done it many times its doable but ya gotta tear engine apart.
