Possibly, IF it is tight against the body on 1 side & away from the body on the other.
Pull out one side & push in the other.
BUT before doing anything else, check the fit between the CAB & BED
At the assembly line, they don't measure anything before they use the Impact Wrenches to tighten everything down.
As they lower the CAB onto the Frame, or lower the Bed onto the Frame.
At the Warren Michigan Assembly Line ..There is a Hole in the Frame & a Hole in the Cab or Bed.
As the body part is lowered onto the Frame, 2 people Align the body & frame part up using Metal Rods, that guides the parts up so that the Bolts will fit in the holes.
If the bolts fit in, they are tightened down.
Sometimes the cab & bed are an inch or more crooked
At the Sterling Heights Assembly, where they assemble the Gen 5 Rams, the same process is done with Machines, they show it in this video, the video
was not put together in Sequence,
USA Dodge Ram 1500 TRX Pickup truck Production line. Building in Stellantis United States factory 2024 from start to finish. How it's built?00:00 How Ram Tru...
www.youtube.com
3 minute version of Ram Assembly
Video of the Assembly Processes at FCA's Sterling Heights Assembly Plant - Building RAM trucks.
www.youtube.com
