Dave79
I have a 2014 Ram 1500 Longhorn. One day when I was working at the back of the truck while it was on I heard the air system pressurizing then lift the truck, a few seconds later I started hearing it vent /burp and the truck would lower with each vent before the air compressor would kick on and inflate it again. I got the service air suspension which i assume the pump overheated and the system shut down. To my knowledge I do not have any leaks in the air bags because they will stay inflated for days when parked. When driving I get about 20 - 30 minutes of the system working then the service air suspension comes on and can feel the suspension loose air and become bouncy. If I let it sit for awhile while I am at work the system works fine or I get another 20 30 minutes of good use.
Why is the system venting out after inflation until the motor overheats or if I get lucky it stops venting to hold pressure all day.
Thank You.
Thank You.
