DWDurr57
- Jan 9, 2022
- 10
- 4
- Location
- California
- 2009/2022
- 6.7 diesel
I have Alum rims on my 2022 Limited 1 ton dually. Apparently the inside rear rims are steel so every time you want/need to rotate tires you must remount/balance tires so that the alum rims are alway on the outside. Is there a reason / weight requirement why I can’t replace those steel rims with factory alum rims a not have to remount/balance tires every time I need to rotate tires. I’m thinking that at $120 each time I rotate tires it would take long to recover the cost of 2 new alum rims.
