crxpd
So I’m kind of stuck here, I just bought a 2001 Dodge Rame 1500 SLT Laramie the other day and I had to replace the battery on it, now when I try to start it it blares an obnoxious loud alarm system. I’ve read online that I need to put the key in the door and turn it to disable the system but here’s the catch: the drivers side door handle is busted (as well as the key hole) so turning the key in the drivers door handle does nothing. I’ve tried looking in the fuse boxes to see if there is something that can disable it but no luck. Really appreciate any advice/help, Thank you
