sullivan
- Joined
- Feb 12, 2011
- Posts
- 1,929
- Reaction score
- 102
- Location
- Houston, Texas
- Ram Year
- 2016
- Engine
- 5.7 Hemi
Just wanted to show off a little project I did while I was home, upgraded my radar from an old Escort radar.
The dash cam I installed sometime ago but due to time, I wasn't able to hardwire it until now.
The phone mount was a custom idea after researching phone mounts, the only real other option was the Bulletp***** mounts. I didn't really like the way they looked, and I could have some fun DIYing one.
Yes, those are wagos. I tried something new, I am always looking to add things to the toolbox of supplies. The wagos are still under trial, however I went on a 4,000 mile road trip and never had one issue regarding the power setup. I was really impressed with how well these worked, a huge time savings and about $1 a piece.
The radar and dash cam are mounted via a custom setup Blendmount. I ordered the radar mount from blendmount, and then I was able to order just the dash cam mount portion. Blendmount DOES NOT offer a dashcam / radar setup, so I had to improvise.
![XSzRBDu.jpg XSzRBDu.jpg](https://www.ramforum.com/data/attachments/512/512567-afa0a1dc38893d2ab301bfe16174afef.jpg)
Trim down Valentine harness, all wires get ferrule connections are connected via Wagos. I've always wanted the tool to install ferrules so this was a lot of fun.
![ZmEaR7k.jpg ZmEaR7k.jpg](https://www.ramforum.com/data/attachments/512/512568-bdb4ade15ab4ff21d92e1856ae02f542.jpg)
![3tXRC8q.jpg 3tXRC8q.jpg](https://www.ramforum.com/data/attachments/512/512569-002e10e56c97fbfb72cfb473d173bfb2.jpg)
Clean
![vfKh2aY.jpg vfKh2aY.jpg](https://www.ramforum.com/data/attachments/512/512570-cfcda0f39e62462375508c2a6a7e76f6.jpg)
I purchased a wiring harness splitter off ebay, again going for a clean install. This plugs in where the USB / cig lighter outlets are and will provide switched 12v+ power.
![62klV7r.jpg 62klV7r.jpg](https://www.ramforum.com/data/attachments/512/512571-554f1f8a1a0aee179115565cbadb033e.jpg)
From here on, everything got tucked down into the lower left of the center dash, just barely above the bottom of the dash, so I can replace any fuses... OR QUICKLY install another 12v accessory thanks to my Wagos. The radar and dash cam pull a combined draw of less than 2amps, this give me peace of mind as outlet circuit is protected by a 15 or 20 amp fuse. You may also noticed the fabric tape, it helps the wiring look cleaner and factory.
![ec3gFyd.jpg ec3gFyd.jpg](https://www.ramforum.com/data/attachments/512/512572-841944cb70adf1b1ba0647909d402870.jpg)
Now on to the phone mount, this consisted of 4 parts.
Ram Mount track ball 1" https://www.amazon.com/RAM-MOUNTS-RAP-B-354U-TRA1-Diameter-Attachment/dp/B00FE66K86
Ram Mount touch track https://www.ebay.com/itm/184771392808
Ram Mount X-Grip https://www.amazon.com/Cradle-Holder-Universal-X-Grip-Cellphone/dp/B0055PH0XA/ref=sr_1_2?crid=3NRMXGTLV0ZOT&keywords=ram+mount+x+grip&qid=1687011192&s=automotive&sprefix=ram+mount+x+gr,automotive,484&sr=1-2
Ram Mount 1" Ball Medium sized arm https://www.amazon.com/RAM-Mounts-RAM-B-201U-C-Compatible-Components/dp/B000UGZTQO/ref=sr_1_3?crid=3FKE3NER0FYLC&keywords=ram+mount+1"+medium+arm&qid=1687011294&s=automotive&sprefix=ram+mount+1+medium+,automotive,486&sr=1-3&th=1
Originally the track mount was 9" long, I wasn't sure what size to order, and appeared online that it was easy to cut and modify to my exact length. I utilized a caliper to measure the holes exactly and then made my cut.
![svHy9aJ.jpg svHy9aJ.jpg](https://www.ramforum.com/data/attachments/512/512573-fcdf674017dce9c7cf2984ad121c2bc4.jpg)
I applied some double sided tape to dampen vibrations and add some rigidity.
![mXw4Bqn.jpg mXw4Bqn.jpg](https://www.ramforum.com/data/attachments/512/512574-47345ddae7539f83a905bf7dc6cf459d.jpg)
End result, currently running a dedicated android phone on a niteize mount while I decide how much I like the new custom RAM Mount setup. Which btw, 4000 miles were put on the truck after this install and everything performed great and exactly as expected.
![zvLG703.jpg zvLG703.jpg](https://www.ramforum.com/data/attachments/512/512575-d2366461996de676acfc06711aaaa263.jpg)
Old BlackVue mount still left on the windshield, I know I know...
![GgsCK3H.jpg GgsCK3H.jpg](https://www.ramforum.com/data/attachments/512/512576-4aec5876cdaa8115024827445e76b522.jpg)
![VvNleuT.jpg VvNleuT.jpg](https://www.ramforum.com/data/attachments/512/512577-8253f81529f2dd11ff4340849a06076a.jpg)
Clean
