Does Ram Care?
DoesRamCare
USA
BLUF: Does Ram care about their customers? Their product quality is certainly disappointing as multiple vehicles have repeated issues that need repeated repairs.
I have been a Ram owner for over a decade now. Including my current truck my last four vehicles have been a Dodge Ram 1500 in different versions. I was always very happy with the quality and reliability of my Ram trucks, but lately I certainly no longer feel this way. My first two trucks were a 2013 Dodge Ram 1500 and 2015 Dodge Ram 1500. I didn’t have any issues with either of these vehicles. A few years later I decided to purchase a brand new 2018 Dodge Ram Rebel 1500. This vehicle is when I started to have issues with Ram products.
I decided to purchase a truck that I was going to keep for a few decades. I thought I found that with the Rebel until the problems started. One of the features of this truck was the air ride suspension which I had never had before. The entry / exit mode of the system was very useful for me as it lowers the vehicle a few inches. I take care of my ailing father and the entry / exit mode made it easier for him to get into and out of the truck when I take him to each of his appointments. This is the main reason I chose to add the air ride suspension system. This system does not perform well in colder weather. This is problematic as I live in the snowbelt in northwest Pennsylvania. There were multiple times where I would go to use my truck and the front end was sagging while the rear end was still at normal ride height. Each time this happened I had to take the truck back to the dealership. I keep detailed records including vehicle maintenance records. The record from November 2020 states “system low on nitrogen causing pump to run excessively which blew fuse”. This work was covered under the warranty and did not cost me anything out of pocket.
This issue happened again in January of 2023. I took the truck back to the dealership and the maintenance record from this visit states “scan for DTC’s found leak while venting.” This visit didn’t cost me anything out of pocket, but the same issue occurring again was certainly an inconvenience. In March of 2025 this issue occurred again for a third time. The front end was sagging with the rear end still at normal ride height. The maintenance record from this visit states “Low air mass and unable to obtain desired ride height faults all active. Inspected air ride suspension system for possible leaks. Both front air springs / struts leaking. 30 amp fuse for air ride suspension compressor blown also.” I was told by the dealership that I was just a year past the work being covered by a warranty so I had to pay for everything out of pocket. The dealership was able to find some aftermarket components instead of me having to buy all OEM parts. The dealership saved me about $1,000 by doing this. However, even after these savings my total paid out of pocket was still $3,501.35.
I am very easy on my vehicles as I don’t travel very much or very far. I only average about 4500 miles a year. At this point I had the 2018 Dodge Ram Rebel 1500 for seven years and I only had about 31,000 miles on the odometer. Even if a vehicle is paid off repeated expensive repairs easily cost you the same amount or more that you make on payments. I realized that this air ride suspension issue was going to keep reoccurring and now that each repair was going to cost me out of pocket I decided to get a new truck. I wanted the 2018 Ram Rebel 1500 to last me a few decades and I wanted the new truck to be the same.
At this point I felt that the Ram line of trucks was still a good option as long as the air ride suspension is not included as the system does not perform well at all. I started looking around at different truck options and then I saw the Rebel X which is the 10 year anniversary version of the Rebel. I was looking for a new truck for the first time in seven years and it just happened to be the same and only year that the anniversary edition was offered. I liked all the new features and decided to design exactly what I wanted in a truck I was going to keep for a few decades. My final design for the vehicle came to $82,865. I went with almost every option except for the air ride suspension which was the whole reason I was buying a new truck in the first place. The truck took a few months to build and it was finally delivered on May 16th, 2025. I went to the dealership after work drove it off the lot around 6pm the same day.
Initially the new truck had no issues and then the problems started. Multiple systems began to act oddly including the transmission, the power windows, the power tailgate, the wifi, and the weather application. Each one of these systems had to be “programmed to latest level per the service bulletin instructions.” While each of these systems now function properly with the latest programming several issues still remain that have become a major hassle.
On September 12th, 2025 I went to leave for work in the morning and my truck was completely dead. I had just driven it home from work the previous afternoon without issue. It took me about an hour and a half to get the truck started. I am an hourly employee and your product made me late to work for the first in 14 years with my current employer. I had to wait for my neighbor to bring me a jump starter to use because of another issue I have with your product. I have a tonneau cover on my truck bed which also happens to be where my jump starter is kept. Unless I missed something obvious there is no way to open the tailgate when the truck is dead if you have a tonneau cover on your bed. Is there no way to open the tailgate with a physical key? If so, that seems like a major oversight in the design phase of your vehicles.
The vehicle had to be returned to the dealership and they had to work on it for several days while trying to figure out why a brand new vehicle battery had died over the course of less than a day. During this work it was discovered that a module was malfunctioning and would not program. This maintenance record states “Attempted to perform radio frequency hub module update. Tech stated update would not complete.” The dealership replaced the module as it seemed to be the system that was draining the battery. This work was completed on September 18th, 2025 and was covered under warranty. However, the Ram Card access card would not program and the truck would eventually need to be returned to the dealership.
I took the truck back to the dealership on October 21st, 2025 to have the Ram Card programmed and it failed again after several attempts. The dealership contacted support was told that after so many failed attempts the module should be replaced. I brought the truck back to the dealership again for this issue on November 11th, 2025. The module again failed to program and the Ram Card still doesn’t work on my brand new vehicle. A new module was ordered again and I had another appointment scheduled on November 28th, 2025. On November 14th, 2025 the check engine light came on. There appears to be a safety feature where the remote start function is disabled if the check engine light is active. This is a major problem when you live in northwest Pennsylvania and it is winter. When I took the truck to the dealership to have the engine code identified it was for an evaporation hose issue that currently has no fix available. The engine code was cleared and the remote was functioning again. Why would you have the engine disable remote start when it is just for a recall that currently doesn’t even have a fix?
On November 18th, 2025 I drove the truck to work. When I went to leave work a little over 8 hours later the truck was completely dead in the parking lot. When this happened the first time the service department at the dealership recommended I buy a jump pack to place under my back seat. This was necessary as I yet again couldn’t access my main jump starter in the bed of my truck. I used the jump pack to get vehicle started so I could drive it to the dealership. They gave me a loaner vehicle and took the truck in immediately to work on it as clearly something was still wrong. After about a week the dealership replaced another module and they believe the issue is being caused by the auxiliary battery draining the main battery. I still don’t have the vehicle back in my possession as they are still trying to get the Ram Card programmed.
At this point I only have about 2600 miles on my 2025 Ram Rebel X 1500 that cost me $82,865. There shouldn’t be multiple issues occurring multiple times on a brand new vehicle with only 2600 miles. After the air ride suspension issues with the last truck and all of the repeated issues in only 2600 miles with the new truck I no longer feel that the Ram brand is reliable. I shouldn’t need to be concerned that my brand new truck will be dead every single time I go to use it. This is in addition to all of the other issues with the brand new vehicle. Does Ram Care?
RamCares
n/a
n/a
Hello! We understand your feelings of frustration. Please know the above is not the experience we want for you! For our team to review and determine a course of action, then please share your VIN with us via private message. We're here to listen.
Hannah
Ram Cares
Docwagon1776
Midwest
I didn't read your entire post, but no they don't. Or, if they do, they are powerless to do anything anyway. Copy/paste of my standard response after dealing with them for about 3 months on a transmission issue.
You can see my previous posts, but Stellantis has outsourced all of their warranty authorization work to India. They, along with RamCares, are largely useless. The only thing that finally got my issue resolved was an email to the CEO and his assistant.
This is the contact info for his current executive assistant:
Nick Cappa
Office: (248) 512-4266
Cell: (248) 202-8039
[email protected]
[email protected] for Tim, but be sure to include both.
I went from:
Service advisor
Service manager
Ramcares (multiple times from here on)
General manager
Dealership owner
Cappa/Kuniskis email
Which put me in touch with Vanessa in Executive Customer Service who finally got it resolved.
JD Martin
Southeast
I hate to hear those kinds of issues, that does suck. The only thing I would comment on is expecting to keep a truck - any vehicle these days - several decades is unreasonable. Technology changes too fast, parts become unavailable, technicians ability to fix old technology gets scarce, insurance companies quit wanting to cover old vehicle, etc. To me, several is 3 or more, and I don't find it likely that anything you buy today is going to last you 30 years. I still have my 1995 Miata, which is 30 years old now, but it is old technology and even given its popularity parts are starting to get hard to find and the guys at Mazda look at it like it's a Model T when I bring it in so I do most everything on it myself these days.
D
DoesRamCare
USA
@Docwagon1776 Thank you very much for the contact info! I have emailed both Nick and Tim and hopefully they will respond.
@RamCares I opened a conversation with you, but each time I try to send you my direct contact information the forum gives me an error and doesn't let me reply at all. Just an FYI!
vlamgat
Nick Cappa
[email protected]
I went from:
Service advisor
Service manager
General manager
Dealership owner
You are quite correct. And it's not very different with all vehicles. There is actually no such thing as RAM any longer. It's just a brand name for marketing purposes. The brand is delivered by a hodge podge of services many of which are not only shared with other Stellantis brands but other manufacturers and industries. And because of its relative youth, Stellantis has a fragmented corporate culture which is pretty well every one for themselves. People are trained and unwilling to stray out of their lanes and especially their pay grades. Just like government but probably worse because most tradition and history has been dumped.
Not that much difference at GM or Toyota and because it's still a family business, slightly better at Ford but these brands have decades of history and employees who have been part of that for their entire working lives. No one can say that about Stellantis which makes the old timers at their brands feel apprehensive Bec of their implicit cost and perception of a lack of loyalty to their new masters.
We see this in many take over situations where the aggregation of the business is more important than the product and thereby the things that make the product perform.
KinnersTowing
Saskatchewan, Canada
6.4 Diesel
I’ve been a Dodge owner since having a Challenger back in 1989 and a new Dodge truck owner since 1999, and again in 2005 and a ram 5500 2013. I even sold Chrysler vehicles in 2006 at a new car dealership with first place in sales as I was a big believer in the company. I’ve have been to the main Chrysler Center (Chrysler World Headquarters and Technology Center (CTC)) back in 1994, filled out every survey they used to send me and ask them to build a new Challenger before the concept of the new Challengers ever came up. I’ve visited the original Dodge Brothers home as it is a museum piece. I currently drive a Dodge / Ram truck. I don’t think they should of ever dropped the name. I think Dodge used to have heart! Stellantus lost heart by dropping it’s name. They didn’t care for the Dodge heritage. Also, they pulled out of Canada breaking contract agreements there and permantly laying off workers shutting down operations as with Chevy. So I think my next truck will have to be a 2026 Ford Super Duty, as I think they may actually do care.
Big D A12
Wisconsin USA
HO Cummins
After spending time "chatting" with the RAM Cares entity, I soon realized it is nothing more than an AI bot. The instantaneous cryptic responses became overwhelming. I no longer waste my time. They have done nothing to help with the glitching review mirror issue I am having along with many other RAM owners. Search the topic under my user name for more info.
D
Crazyjoe
fla
cummins
Well of course, Ram doesn't care. That concept has been gone EVERYWHERE, for a long time. Oh, and AI is just getting started. Ram's specialty is the parts number changing. Same part with a different part number ending. (See if your remote start still works when your hood is open). I'm sure this site will block this, but this is an economic problem, across this and almost ALL industries. It is called corporate, but it really is a billionaire class controlled economy. Even the CEOs must adhere to it. Why would they change when they got you for $82k for unreliable junk. The high tech part(my field) is very much, a scam. Also, the stupidity of the people thinking that these new clowns(nice word) are fixing what the old clowns did. This direction on the topic is endless, but VERY REAL. There are REAL solutions(most, easily implemented). Good luck to the younger generations.
Docwagon1776
Midwest
That's exactly why we're currently considering a pre-COVID 4runner or the Lexus equivalent for my wife.
RAM dropped the "Dodge" well before the merger that created Stellantis. It was done largely for marketing and contract purposes. Plymouth/Chrysler dealers didn't have a truck to sell and RAM becoming it's own brand was a way for those dealership to buy a franchise and have a truck on the lot. FCA also had dreams of streamlining marketing so that Dodge became a performance brand, and performance brands don't have the vast majority of their sales be fleet vans and trucks.
Deltron
Sierra Vista
5.7, Cummins
I have a 2022 HO dually that flat out is the worst vehicle I've ever owned. That's saying a LOT, bought a new Vega back in the day.
Our 2021 RAM 1500 has been stellar. Our 2018 Cummins truck was stellar. This one has been back to the dealer multiple times with all sorts of different things failing along with nothing but trouble with the emissions. Seems the Star guys have no clue what to do either.
From what I've been hearing the 2025 and later are even worse. It seems they never even tested the trucks before foisting them off on owners.
I will NEVER buy another MOPAR product as long as Stellantis owns it. Their sole concern is lining executive's and shareholder's pockets, customer be damned.
Red Rex
USA
Stellantis is not making a good faith effort to complete the HSU recall
They have completed 1.2% through the 3rd quarter this year.
I won’t spend a dime with any dealer until they make good. I am also going to discuss the same wit my dealer. We are not stellanris customers, the dealer body is.
They won’t react on any issue unless they speak up for us, their customers.
I urge each of you to talk to your local dealership general manager about your particular issues and ask for their support
SgtAdams4189
Pa
I’m sorry you had those issues! I , like you purchased a 2019 Laramie Longhorn with idea of keeping it awhile. I have had it back to the dealership numerous times for issues, the latest was the rear windshield leaking, they tried a few times to fix it and in the end used silicone around it, it looks horrible. Now the dashboard is delaminating and the dealership won’t cover it, RAM cares was absolutely no help. I have an extended warranty that runs through 28 and a 100000 miles but that means nothing. I have 47000 miles on it, I am probably gonna have a local shop do there best with dash and trade it in on a Toyota, my wife has a 2018 that is perfect but any issue they have been great to deal with. I’m done with RAM. Hopefully yours can be resolved
BLUEDERANGO
Law Enforcement
392 Hemi
Stellantis has moved all customer support to India. The people there have no working knowledge of any of the products they supposedly represent. I actually asked one if they had ever even seen a RAM truck and he actually answered, NO.
It's not only us consumers, the few good dealerships out there can't get information or authorization from these so called customer service agents and that definitely complicates a lot of the issues. I have a friend who is the service director at a large Dodge/Ram dealership and he is in constant "communication" or more like "Non communication" with these "agents" and between them having no product knowledge and a very poor grasp of the English language it becomes totally frustrating for all involved.
Stellantis needs to get their Sh**t together !!
Blue Truck
Skagit County WA
No Spark Plugs
I love my Ram!
Oh wait, it's a 2003 DODGE Ram.
Oh wait, it has a manual tailgate.
Oh wait, it has a manual transmission.
Oh wait, it has manual windows and locks.
Oh wait, it has no cat, DPF, DEF, regen, etc. and never did.
OP, you have my sympathies.
rayrmjet
Arkansas
Hemi 5.7, Hemi 5.7, Cummins 6.7
When I rebuilt my 2013 5.7 hemi, I wish I would installed an LS engine. Some day I will find someone that will fix the die at every stop problem and others.
JD Martin
Southeast
I love my Ram!
More features can be more things to break down for sure. You see this all the time with appliances. I'm sure your 2003 Ram has (or at least had, when it was new) a catalytic converter as they have been mandatory since the 70s. And some features are more durable than 'manual' alternatives. I've had plenty of hand-crank windows strip out on me but have never had a window motor die on me (but have had a switch go bad, a 5 minute fix). Your point is well taken, but no point in wishing for the past because no one is going to build that truck any more.
vlamgat
All your references to car names are meaningless today in the context of say 2000. None of those companies even exist. Yes the Chrysler Corporation that built cars before the bankruptcy was liquidated and some of the passengers purchased by Chrysler Acquisition Corporation which later changed its name before becoming a subsidiary of Stellantis and rehiring some of its staff. This is the Wacamo game of corporate property and anything that once was is no more except in terms brand aspirations as defined largely by social media.
I owned some Maserati/Stellantis assets which after the Stellantis creation I wanted to purchase or return. I couldn't find anyone who would accept them. Eventually I sued them to get a court order demand that they accept them (new spare parts) and we settled by them selling the parts to me.
Ford is a possible exception having not elected to take government bail out money but it's struggling to retain non revenue assets like customer service and warranty support.
Docwagon1776
Midwest
And they are moving *more* operations to India. I don't know if they are contracting it or actually setting up as an employer there, but I suspect they are contracting it. If that's the case, the "Ram" employee is probably doing customer service for multiple companies and only knows to answer the phone as Ram because that's what the screen tells them is the line coming in.
