crazykid1994
So to start this off I had an mds lifter collapse. Loud ticking located to one side of the engine. Pulled valve cover and noticed one rocker didn’t move as much as the rest. Order an NSR NTR cam and cam kit from moes performance. Pulled the engine apart. Marked the cam phaser and chain. Installed the new cam. Reassembled the engine. Now the engine does not run. Throws codes. Intake manifold feels like exhaust may be blowing back into the intake as I feel heat on the intake manifold. AFR gauge reads rich. Possible I mixed up the intake and exhaust pushrods on one side? If I hold the pedal down truck starts but will not run under 2000 rpm. Any ideas before I have to tear apart the engine again… I am 100% sure the timing was correct. Everything seemed to go together perfectly. Also not sure on the tcm code.
![IMG_7228.png IMG_7228.png](https://www.ramforum.com/data/attachments/537/537193-d62e0cd65734bdb378a05e864d3cd35d.jpg)
