Engine stand
New2dodge
4.7L
So just pulled my motor. First time ever pulling one and can’t get it on the engine stand. Measuring I would need 6” bolts to hold it on. Is this normal or am I doing something really wrong?
Green_Manalishi
Looks to me like you need to remove the flywheel and converter. 6" bolts aren't the solution.
Daw14
This ^^^^^ , finish removing the flywheel and torque converter. That will make it closer.
20IndyRam
Extreme Northern Indiana (Michiana)
EcoDiesel
Agree with the previous posts...
In addition, buy grade at least grade 5 (preferably grade 8) bolts. Depending on whether you have intake and heads installed, you will have 500+lbs on that stand. Do not trust that to hardware store soft (grade 2 or less) bolts.
This is a big fast forward, but - I personally would never try torquing heads on an engine stand. I've never tried a modern Hemi with AL heads. I have tried the older cast SB and BB heads on 60's, and 70's vehicles. You can't get a good torque with the springiness of the engine stand while it's chasing you around the shop. Torque them to a low/equal value on the stand and then finish in the vehicle.
N
New2dodge
4.7L
Thank y’all for the advice. I’ll be removing it today. Also will be getting some grade 8 bolts.
