Fixed oil leak now low oil pressure
Marshall
Sk, Canada
2014 sport
I was thinking it would be the O ring, they are easy to mess up and should always use a new one with a bit of lube. You may have, I skipped some posts.
Should be smooth sailing now, we hope :smoke2:
sblack33741
Maryland
3.6L Pentastar ETorque
also note i did drop the oil pan to fix this oil leak and replaced the oil pan gasket but i KNOW for a FACT the o ring on the pickup tube is on its a new o ring and just no chance it came off, the pickup tube screen was clean when i removed it, so im at a loss only other thing i can think to do is buy a mechanical gauge and check it that way, but the sensor is less then 500miles as well so i dont know...
You seem to have oil restriction for your pressure to drop.
Bigskyroadglide
Montana, except for work
Hemi 5.7, supercharged
I'd still be concerned with 20-25 psi at idle. At idle 3 out of 4 of my rams are 48 psi at idle and the new one with 3k miles is 40 psi.
What is your idle rpm? Factory 550 or higher?
dmullenex
dmullenex
Durham nc
idle rpm is like 900, motor has 290k on it though so i dont expect 40psi at operating temp idle.
