win-er
Hi guys !!
Hope you are doing well.
I just bought a 2006 Ram 1500 SLT crew cab with 5.7 Hemi with 28k miles here in Switzerland.
My project is to make a soft upgrade of the truck and I would like your opinions and advices.
I plan to order :
- K&N air filter DRYFLOW, ALUMINUM TUBE https://www.knfilters.com/71-1533-performance-air-intake-system
- Magnaflow exhaust https://www.magnaflow.com/products/...et-series-cat-back-performance-exhaust-system
- Bilstein B8 5100 front and rear shocks with a 1inch front lift (don't like when the front looks lower)
- double din radio.
- Trail Terrain tires (don't know which ones yet, maybe de BFG Trail Terrain) what is the biggest tire that we can put with no lift?
- Led bar from Lazer Lamp https://www.lazerlamps.com/fr/catalog/product/view/id/985/category/21/
The truck has few problems:
- there is a oil leak on the rear diff. I just order the rear pinion seal and I will do the rear diff oil change with mopar 75w140.
- engin light and break light+ABS turned on and off few times -> P0158 / P0573 / P0138 / P1521
- the RPM indicator is sometime bugs and the engine idling seems to be very low (around 500rpm)
- the right dash speaker crackles. Do you know if I can order OEM infinity speaker or I should change both dash speakers? what speakers do you suggest?
- the truck s"*ks gas as F*"% !!!!! and 200$ for a full tank hahaha
thank you for your feed back !!
Erwin
I plan to order :
- double din radio.
Erwin
