I read over @ Booob's that PIB PolyIsoButylene gasoline detergent additive isn't as effective as PEA PolyEtherAmine, because it doesn't have nitrogen to stabilize the detergent molecule in hot environments, so it's especially less effective in direct injection gasoline engines (keeping the injector nozzle clean).
Of course, in a GDI engine, the intake valve isn't cleaned from PCV oil mist anymore because fuel isn't sprayed on it, so it requires a detergent fog cleaning every so often. If these stupid companies would make GDI engines correctly with dual injectors, this extra step would be necessary. I believe Toyota is.
PIB is old, Chevron invented PEA 10 years after. Chevron no longer advertises PEA nor lists it as an SDS ingredient. My concern is they got some bean counter CEO's the cheaped out and went to PIB at the exact time PEA is most needed because of proliferation of GDI engines.
Anyway, my Red Line PEA arrived and I've started dosing. Who knows how long I've run non Top Tier gas for? I occasionally stop at Shell, but had been mostly going to Holiday (Circle K). Cheap ba$tards.
