Hemi 5.7 2500 help
cpdodge
Idaho, United States
2003 & 2007
5.9 2500 & 5.7 hemi 2500
Needing some ideas on what this could be.
07 5.7 hemi 2500 megacab.
Truck drives fine until weather. ( rain, snow, etc ) and then it’ll randomly start glugging at sometimes 1500, usually 2000 or sometimes 3000 RPMs. Turn it off, turn it back on and you’re good for a bit. Once it dries out if you disconnect the battery it doesn’t do it again.
It came to us with fuel problems that we’ve fixed. Aside from that we haven’t done much.
Brandon-w
Yukon
2015 Ram 1500
Put a fuel pressure gauge on it and see what it is when it starts. Dodge uses pwm (pulse width modulation) on the fuel pumps to keep the fuel pressure where it needs to be. They do this because the fuel regulator is in the tank and there is no return system so it dials back the pump as needed. Just a guess. Seeing as it previously had fuel issues this could be something underlying in the system.
C
cpdodge
2003 & 2007
my sending unit had gone bad, so we dropped the tank. Ended up needing to completely replace tank, so it got a new fuel pump with that. It started a month or two after the fuel tank replacement now that I think about it.
But when it’s doing it it’s acting like it can’t shift.
Sorry if I’m all over the place, I’m not a very mechanically savvy woman.
Administrator
If it acts up when the vehicle gets wet, most likely water getting into an electrical connector somewhere.
How old is the battery? Also check the grounds to the engine and body.
C
cpdodge
2003 & 2007
Battery came with the truck, so I’m not sure. We plan to replace it this week regardless.
jws123
nj
Did you scan the truck for codes?
C
cpdodge
2003 & 2007
It was scanned not too long ago. I plan to take it to the auto parts store and have it scanned.
Everything I’ve read talks about the APPS or TPS. It sounds similar to what those symptoms are.
C
cpdodge
2003 & 2007
Here’s the codes read today :
P0174
P0171
Those we knew about.
C1036 which is my rear wheel speed sensor? We’re going to check the connection. Would this cause limp mode?
jws123
nj
P0174
P0171
yes both of those will cause issues.
