Installed On-board Battery Maintainer
Longhorn1500
West Sound, WA
2019 Longhorn
Cummins SO
I just finished the installation of a NOCO GENIUS2, 2A Smart Car Battery Charger on my truck.
Since the truck sits for long periods, I thought it would be nice to be able to keep the batteries topped off.
I previously installed a power inlet plug on the rear bumper that I use to power both an in-bed outlet and the block heater that's on a switch in the bed. So I added a plug with the block heater to power the battery charger at the same time.
I mounted the battery charger to an aluminum plate that I fastened to the under hood auxiliary switch fuse box with double sided 3M foam tape.
stevenP
northern Indiana
2022 2500 Longhorn
6.7L Cummins
I left the tender on the bench, ran the permanent plug in the truck to the outside of front fender. I did like the AC cords in the truck, possibly getting damaged and causing a short.
