Barney556180
Don't need no stinkin' mask...
- May 14, 2018
- 302
- 273
- Location
- Northern Michigan
- 2014
- 3.0 EcoDiesel
Hello all,
I installed a pair of 3157 LED Tail/Turn/Brake bulbs along with 50w 6 ohm resisters on my 2014 BH. Everything works correctly on the passenger side with no errors.
However the identically installed driver side has issues that don't make sense to me.
Appreciate any suggestions or troubleshooting steps I should do to get this resolved.
- The LED blinks at the normal speed. The dash turn indicator and mirror turn light fast-blink and displays a "Left rear turn signal light out" error message. The mirror turn light and front turns are OEM.
- I verified the resistor is good, and connected across the turn signal and ground wires.
- I swapped the LEDs with no change. When I reinstall the original incandescent bulb it blinks normally. Initially the dash and mirror fast-blink, then after about 10 seconds everything goes to normal slow-blink operation with no error message.
