Low Voltage Battery light on
Intoodeep713
Houston TX
I have a 2018 Ram 1500 Laramie, Crew Cab 4 Full-Size Doors, Four-Wheel Drive, 5.7L V8 Gas
I changed the spark plugs and coils
I changed the fuel injectors
I changed the alternator and belt
I changed the battery
I changed the battery fuse on the positive terminal
I changed the black box on the negative terminal
And after all of that work the low voltage battery light is still on and if anyone can help me with what the problem is I would be so grateful
Thank you
BossHogg
Oakland Township, Michigan
6.7L Cummins
As you likely learned, firing a parts cannon at a problem usually does nothing to fix the issue but is very successful at draining your wallet.
Most of what you changed has nothing to do with a low voltage indicator and a new battery does not mean the battery is good.
I would start by measuring the voltage at the battery (battery posts and battery terminals) while the engine is running. If the voltage is 12.2 or something like that, it would suggest the alternator isn't working. If you measure a voltage around 13.5 or so, then the system is working and you have a battery connection issue or a grounding issue.
Administrator
neither does a new alternator, there's been a couple of alternators that were replaced only to have the new one is bad also reported on the forum.
