BulaienS
- Dec 12, 2020
- 17
- 3
- Location
- Genesee Depot, WI
- 2020
- HEMI 5.7 V8, 3.92 Rear Axle Ratio
I've been working on replacing the incandescent Map Light bulbs with LEDs in my 2020 RAM 1500. It was going well until I short-circuited one of the lights while installing the LED bulb. Now, I'm trying to find the correct Fuse Number since the fuse table in the manual is too cryptic to tell what the "Map Light" is. Does anyone know what the fuse number is? BTW, if I had known the exact Fuse Number, I would have removed it before working on the light replacement.
ALREADY an UPDATE! (Same day): I found it!!! By removing suspected fuses, it is F30! It turns out there was not a blown fuse, thank goodness. I replaced the Map Light bulbs by just removing the lens and the plastic chrome plate reflector. But trying to get a good connection took a bit of fussing around since the contacts move when inserted (making me think I had a blown fuse). So you need to have the power to know that you have good contact. Even so, it would have been nice if I knew what that Map Light fuse No. was at the beginning.
