Mr M
So on my newly purchased 2019 1500 warlock, the turn signals in thei mirror are not working, nor are the puddle lamps. These are all LEDs and all working properly as I applied voltage to them, I am not getting any current going to any of these lights, I have nothing coming out of the door control module on the wires going to these lights, and the lines do have continuity because I checked from the base of the fixtures down to the door control module. Everything else works as far as the power windows the door locks etc, can I assume that both of these door control modules are defective not allowing the signals and puddle lamps to illuminate? Is there something else I can look for, again wiring is good from the door module all the way to the fixtures. Any help would be greatly appreciated, thank you!
