MMX no tune required cam. Anyone running it?
Ram7081
Ram7081
HEMI 5.7
Tune + trans is $1500? Tune, PCM, programmer.
This is on par with that, no?
Ram7081
Ram7081
HEMI 5.7
Called around. Looks like labor is $450 and new MMX cam is $620 for this setup @ 30hp. So, $1070. That's cheaper than a tune, programmer, and pcm swap ($1500). Thoughts?
RedSRT4Me
Scottsdale, Az
2015 CC Sport
First, I know there is better and more power cams that require a tune. But, a cam swap and you get 30hp and no tune is required has me looking at it. Anyone running it yet? MMX said per chat 2009+ 5.7l. 30hp/tq gain.
https://www.modernmusclextreme.com/...d-nsr-mds-performance-na-camshaft-by-mmx.aspx
I think that's an excellent offering. In fact I might go that route first because of a few reasons
Don't have to pull the heads
Don't have to change valve springs.
Don't need the top end rebuild kit.
Then when I'm ready for that stroker kit I can do all the above later along with another cam to fit the stroker motor profile.
Ram7081
Ram7081
HEMI 5.7
Ya, I am really thinking about it
Tim Garceau
Banned
Eagle River
2014 Sport Quad BSP
3.92 8 Speed 5.7 4X4
Would need to see a dyno slip, if you're losing 30hp/30trq down low under 3000RPM where a truck needs the power and gaining it up top that's a downgrade IMO.
Probably meant for the R/T cars...
brad_12
Independence, WI
Would need to a dyno slip, if you're losing 30hp/30trq down low under 3000RPM where a truck needs the power and gaining it up top that's a downgrade IMO.
Not sure if they have a graph or not, but in the description says "This camshaft has added 30 Wheel HP to our 2019 Ram 1500 5.7 Laramie, as well as a noticeable increase in low end torque."
Ram7081
Ram7081
HEMI 5.7
Per convo (what's its worth) MMX said all gains are "where the factory specs are".
Ram7081
Ram7081
HEMI 5.7
Per chat convo, MMX said the tq and hp increase was about the same. I asked in top rpm range or? He replied both in the factory cam rpm range.
Tim Garceau
Banned
Eagle River
2014 Sport Quad BSP
Duration and separation angle similar with more lift to keep the PCM happy, 30/30 on a stock motor seems optimistic...
To the tires, doubtful... That's why they don't put guarantees on the box any more Tommy Boy.
Ram7081
Ram7081
HEMI 5.7
Says to the tires "This camshaft has added 30 Wheel HP". I asked for dyno slip. We'll see. Ill post if they send one.
RedSRT4Me
Scottsdale, Az
2015 CC Sport
30 is probably with other bolt-ons like headers.
30/30 really isn't that hard to believe when the high lift tuned version are producing 70whp with supporting mods.
Looks like they offer it as a MDS delete cam to.I'm guessing that one would need a tune of some sort ,otherwise it would probably turn on a light/code for the MDS. I'd like to see a dyno sheet to,as it'd have to be a torque monster down low,to add any horsepower to the equation at the factory 5600 rpm limiter
ScLeCo
Earth
Supercharged 426
I really don't get this desire to avoid a tune. Anything worth doing is going to require a tune. Anything else is just :manos:
GRN69CHV
Pennsylvania
Been there, done that with many engines. Newer truck, low miles, small increase in lift and duration, OEM valve springs are probably ok. Higher mileage (I'd say 40k+ which isn't really high for stock cam design) I would swap out the valve springs. These motors run beehive springs, they are spec'd for a certain rpm range and compatibility with the lifters. Serious power gains are made by increasing lift and that costs $$$$. BY the time you swap out cam ,lifters (pull the heads) springs, pushrods retainers, you'll be pushing $2K in parts plus labor if you don't do the job yourself. At that point, having it tuned doesn't really add much more cost.
Ram7081
Ram7081
HEMI 5.7
They have the truck on youtube. I don't believe it has headers. Muffler was removed and cai only.
