No. Camshaft is pretty long. You'll have to pull the radiator, condenser, and the grill to pull it out. Unless you pull the engine, then you'll have plenty of room.Question: is there enough room to swap a cam without removing the radiator?
Yes,and you have the gold plated 1234 freon,so you'll want to evacute it,and have a shop store it for you.You can do the job with-out opening up the A/C system,it's just a bit more difficult,but by no stretch is it impossible to pull the cam with the condensor still in place.Look at CrazyKids post #83,his picture shows him working around the condensor.Maybe a stupid question: if you pull the ac condenser, do you have to bleed the ac system?
