Atcer2018
Virginia
That's not encouraging. I hope this latest attempt works out for you. Meanwhile, I'll be awaiting the inevitable oil stains in my carport as I watch Youtube videos on how to perform this repair :oops:.
My experience replacing the unit was about the same as BenchTest described. It’s not a particularly difficult job just frustrating at times. That crossmember in the engine bay is your best friend and I too stood on it for much of the repair. Wear good supportive shoes! If you have one of those articulating ladders that have multiple positions that may come in handy as I put one section inside the engine bay and the other end on the garage floor to form a flat platform to sit or lay on. The laying down part didn’t work so well for a 60 year old and sitting on it requires reaching over at the waist if you’re tall. It’s mostly basic hand tools and a torque wrench job.
B
BenchTest
Midwest
I'm 50. I felt that repair for a couple of days. You really load up the leg and back muscles standing awkwardly for the duration of it.
Tony Donato
Banned
North Carolina
You will find out about muscles you thought you never had, that's for sure.
Lift the rear 6 to 9 inches off the ground. It makes it much easier to work under the hood. Use ramps or a hydraulic jack and jack stands for safety.
B
BenchTest
Midwest
Can just go 18" of lift on the rear and do a ZF trans drain and refill when I'm done :)
B
BenchTest
Midwest
I'm probably late to the party, but I just did the "partial Active Grill Shutters delete". Removed all but the top and bottom row of the shutters. I elected to remove the AGS assembly and gently remove them in case my findings were not favorable and needed to re-install. It was a simple surgery. Here are my findings. It's been 90-95 degrees here and on the hwy running 70ish MPH, with the AGS intact, my coolant temps ranged between 195-224 CONSTANTLY. UP and then DOWN, and then UP and then DOWN, with what I assume is the cycling of the shutters. This was true with or without AC on (yes I manned up and killed the AC for part of the test when it was 95 degrees and 80% humidity, lol). The oil temp was always in pursuit of those numbers as well, for obvious reasons. The trans varied from 174-188 with the shutter cycles. Once the AGS center shutters were removed I repeated the drive cycle. Coolant and oil temp stayed between 195-199 while driving with or without AC. Trans temp stayed on 183 about 95% of the time (my readings show this ZF trans is internally regulated to 183-185, so that reading is good in my book). The only time coolant/oil temps raised was at idle/stop, and then it only crept up about 2-3 degrees. No more 25-30 degree temp swings, so I consider this a win. Stable temps are better in my book. Was a simple mod to make. Don't anticipate any CEL/MIL flare ups with this either. Seems like a pretty well tested MOD in the forums.
HunterCat
Central NJ
3.6 V6
Regarding the oil filter housing, I've been thinking about this a little more. The latest part number from Mopar seems to be 68596317AB. This replaces a LOT of prior iterations. It would be interesting to see the date when this latest part number was introduced. They must have made several attempts to try and mitigate this issue by changing the part. Again, would be interesting to see when the latest version came out and what the change was. They seem to have had black o-rings in the past and now they are orange. So at the very least, they've changed the o-rings. Also, some people have reported a change in the thickness of the plastic border surrounding the o-rings.
Not sure how to get any of this information. Any ideas from the more savvy members here?
Tom57
3.6 V6
I'm late and I'm a new member here - after reading this post I guess there's a problem with the plastic oil filter housing, stripping the threads, over tightening it and cracking the unit ? Right ? Doing my own oil changes I'm not that stupid to do that. I can understand if you take it out to have a technician to do the oil filter change he may over tighten it.
But the BIG issue is I think most owners change their oil too soon, too many times when not needed - 3000 miles is too soon, the perfect miles is 7500-8000 miles. I believe changing oil too soon actually does more harm to the engine by starving the engine dry at first start up after the oil change. Oil doesn't wear out, you change it cause it's dirty, actually when the oil looks dirty it's doing a better job keeping the engine clean. When you have a bucket of soap water and mop your floor when the bucket of water is dirty that means you have a cleaner floor but if the bucket of water looks clean after you're done your floor is still dirty and the soap you used wasn't any good.
Most of you guys go overboard changing your oil, fuel treatments are snake oil, new spark plugs are designed for 100K miles, the only issues with the EVAP systems are the canisters - tubes rust out, hoses rot and wire harness plugs corrode
You guys are doing too much that you don't need to do, the more you touch it the worse it gets, don't "fix" it unless it's broke.
Atcer2018
Virginia
Believe what you want but a simple internet search will indeed point to oil “wearing out”. It loses its additive package. It shears from pressure and heat. The viscosity changes with use. Dirty oil has trapped contaminants in suspension and although the oil filter is tasked with containing these contaminants they still float around the oil galleys. No one ever sludged an engine by changing the oil too frequently.
Atcer2018
Virginia
I’m jealous! I have all but the top and bottom row of my AGS removed but still see temps in the low 220’s when using the AC on hot days with speeds of 70+. No AC or below 60mph it will run 199-205 which I’m happy with but higher speeds with AC on drives up my coolant and oil temps. Prior to the AGS delete temps were 20+ degrees higher. Have yet to figure this out.
B
BenchTest
Midwest
Interesting. Guessing you've chased all the usual (coolant flush and proper mix rate, 194 stock temp thermostat, verified the system is burped, etc)?
B
BenchTest
Midwest
Thanks for the input. There have been issues with the housing cracking due to people overtightening the cap into the housing. There are more issues with the factory o-rings giving up after X amount of miles or hot/cold cycles. "Fuel treatments are snake oils" - That's a broad, blanket statement. Fuel treatments can be quite beneficial in certain circumstances. New spark plugs are in fact not making 100k without significant wear, at least on my application. EVAP has had numerous issues outside of what you've mentioned. I have to ask, what is your background that you feel confident in your statement?
Atcer2018
Virginia
All of the above. Ran 10 gallons of distilled water through the system after oil filter housing replacement, 50/50 mix distilled water and Mopar purple OAT antifreeze. Vacuum filled cooling system. Stock thermostat is 204 for me. Verified e-fan operating during AC cycles. Thinking it may be an AC issue not a cooling issue.
B
BenchTest
Midwest
I'm out of state currently. Just about 900 miles into my trip. I ran 75+/- mph for 11 hours in mid 80's air temp, A/C on and stayed 195-199 the entire time. I'm in the mountains right now. I had pretty cool weather most of the run. Upper 50's to low 70's most of it. Running highway speeds, no AC I almost never moved off 195-197. I dropped into some lower elevations in the mid 80's. At low speeds and pulling grades, I'd spike to 230. I don't like that, but it's within range for these animals. I was in 4LOW in the back forest areas, mid 50's to low 60's and creeping at 0-5MPH over rock transitions, it shot up to 225-230 and stayed there. I tried cycling on the AC but the ambient temperature wasn't enough to call for the cooling fan to be on consistently so my truck was climbing in temps. I never saw over 230, but again, I don't like that. I go into 9k-11k elevation several times a year and several times I'm pulling low speeds, in 4LOW. I think in addition to the AGS delete, I'm going to put a pusher fan on the front side so I can move air at low speeds. During all of this, as soon as I got on the highway and got air moving through the radiator, it leveled right out and went back to my 195-199. Wish there was a way to command that e-fan to come on, on demand, without all the computer variables and cycling on/off at high temps and cycling low speed/high speed. Guess the pusher fan on a toggle/relay will be my fix. If it stayed strictly on the highway, I think I'd be fine as is.
Atcer2018
Virginia
Your numbers are pretty good considering how these engines are set up for maximum EPA efficiency. I have no experience with the elevations you are dealing with. I live on the east coast, 41 feet above sea level and the mountains for me are the Blue Ridge up to about 3500ft.
I too wish there was some control over the e-fan system. A pusher fan sounds complicated. I’ll be watching this thread if you elect to try such a project.
Different Drummer
North East
Pentastar V6
I do not do any rock crawling / off roading. I do at times travel at higher elevations and varying Temp. extremes. Your experience with the steady Temps at highway speed is exactly what I experience. Even our Temps. match . Mine will increase in city / stop and go traffic. I don't think I have hit 230 on the coolant but definitely have seen mid 220"s. Oil temps will rise and fall with the coolant temps. Only difference is at highway speed the oil will be 3-6 degrees cooler than engine coolant Temp. When slow moving or city driving the oil Temp. will exceed the engine coolant Temp. I have often wished that I could manually control the cooling fan. Please keep us updated on your pusher fan install if you proceed with it. I have top two and bottom two grill shutters remaining. Others are removed. I did have all removed except the one top and one bottom. I saw no change in Temps. when putting two more shutters back into service.
B
BenchTest
Midwest
Just returned from trip earlier today. My return temps remained good. Running 75-80mph down the interstate, AC on, ambient temps around 85, 197 was my near-constant coolant temp and very similar was the oil temp. Trans ran a steady 185-188. What I'm happiest about is my trip average was 23.2 MPG. That's combined interstate speeds and crawling in the mountains, up/down elevations at low speed, etc. My trip high was 24.3mpg running around 55-60 at near-steady elevations between towns. I attribute that to new plugs, clean injectors, clean throttle body, new air filter, and steady throttle (no cruise control). Or better said, that's the best it'll ever do for MPG under best conditions. I'll take it. Full-sized, 4 door, 4x4 V-6 pickup with about 500 lbs of cargo/gear/spare fuel, 2 adults, a dog. About 2k miles on this trip and all went well (minus the hot temps while crawling). I have got my eye on a fan for this pusher install. Will update when that gets in motion.
B
BenchTest
Midwest
Love the Blue Ridge area. I lived in Mauldin/Greenville SC for a while and used to run up and down the Blue Ridge. Many great memories of that area. I'm glad the general population is not tuned into that region's beauty, otherwise it'd be overrun with tourists (worse than it is now). You're a lucky person to have the coast and the mountains within a day of each other (just a few hours apart, truth be told). Enjoy it!
Tom57
3.6 V6
The motor oil will last forever but the oil filter doesn't
I simply change the oil filter only and not change the oil, just add enough new oil from what I lost changing the oil filter
When the oil looks dirty that's good it means it's working - when you drain it and it looks clean you're either using the wrong oil or changing it too soon
also a dirty air filter does a better job filtering out the smaller micron partials - the added dirt on the outside of an air filter improves the filtering of the air filter - my opinion is never touch, never open the air filter housing, once you open it you break the air tight seal and the housing never seals properly again
did you know there's an industry standard of 20 to 30 micron for all oil filters......BUT there are NO standards for the micron size opening of air filters? some air filters, especially aftermarket-cheap air filters have a bigger 40 to 60 micron openings thru the filter media allowing more and bigger particials of dirt to pass thru ( micron size is never listed on air filters )
If you feel you must replace the air filter get the genuine Mopar brand
B
BenchTest
Midwest
I don't know if you're here in a serious capacity, but I surely hope not. Your two posts on this thread make me think you're just here to get a rise out of contributing members. If you ARE serious in your statements, I feel bad for your vehicle.
Atcer2018
Virginia
Obviously you are trying to get a reaction from readers, haha. I did have a coworker in the early 90’s with a Geo Metro three cylinder engine. The vehicle consumed oil at such a rate that he never changed the oil merely added more when needed. We called the car the “furnace” but at over 200K miles he got his money out of a $10k vehicle.
How well does your lawn mower run when the air filter is packed with dirt and debris? So much for the dirty filter theory lol
