dieseldave
- Dec 6, 2018
- 251
- 101
- Location
- Little Suamico
- 2021
- 5.7 Hemi
Witch one , pennsoil full synthetic, or pennsoil ultra synthetic ?
I personally use the ultra but if you change it every 5000 miles I don't see how you'll go wrong with either. That's just my opinion, others will tell you to go a lot longer but why chance it to save a few dollars. Oil is a lot cheaper than metal! You're not wasting either, they recycle oil. Again, just my opinion after 45 years of being a mechanic!Witch one , pennsoil full synthetic, or pennsoil ultra synthetic ?
Thanks for your replyI personally use the ultra but if you change it every 5000 miles I don't see how you'll go wrong with either. That's just my opinion, others will tell you to go a lot longer but why chance it to save a few dollars. Oil is a lot cheaper than metal! You're not wasting either, they recycle oil. Again, just my opinion after 45 years of being a mechanic!
API oils will all be similar, but true high performance oils are made dramatically different then shelf oils. If you ever get hemi tick, follow the work of 100's of guys on this forum, the results prove their certainly is a huge difference. The ester and pao base oils along with super high extreme pressure additives and extra detergency then anything you can vuy on the shelf, kills hemi tick at an impressive rate. You can literally kill tick just by changing an oil, yeah it makes a difference. Don't believe a word I just said, but read this thread and the poll results from many ram forum members.Do you really think, for everyday use, one premium is better than another?
And the article says if you were to mix ultra and platinum oils in the same engine it would go nuts and stop halfway. Lol.Pennzoil Platinum Vs Ultra Platinum? In Depth Review
So, who wins in pennzoil platinum vs ultra platinum? Well, basically, both of these models are kind of the same and have a little difference on a tiny point.autokitslab.com
Personally, I run Platinum and Ultra Platinum in my vehicles.
Platinum - 5W20 in the RAM
Platinum - 5W20 in the Mustang
Ultra Platinum - 0W40 in the Scat Pack
That particular article was a joke. I too run pup in my 6.4 because ram recommends it. inlove how the guy says you should not mix them pretty sure pennzoil says otherwise as do most oil companies. That appeared to be written by a marketing intern for amazon or something for people who don’t actually read or care about oilPennzoil Platinum Vs Ultra Platinum? In Depth Review
Typing at same time lol what a joke of an article. Read the last couple of sentences and pretty much tells you the author of the article is cluelessAnd the article says if you were to mix ultra and platinum oils in the same engine it would go nuts and stop halfway. Lol.
I understand that you can dilute the additive package of a particular oil if you mix another oil in with it and may lose some of the benefits of one of the oils detergents etc.but as far as it going nuts and stopping halfway that just doesn't make sense.Typing at same time lol what a joke
