crow5716
I have a 2018 ram 3500
When I manually click the light itself to turn it on it won't work, but when I turn on all the interior lights with the dimmer switch they'll come on and will also cut off if I click the light while I have all the interior lights turned on using the dimmer switch. They also still all come on when the door opens.
Nothing has been upgraded or replaced. It's all factory. So the bulbs themselves are good, and they are turning on and off with the cab light switch that's next to the headlight switch along with the door open switch. Just for some reason the manual pressing of each light that used to turn it on when your in the truck no longer works.
That tells me there must be 2 different power sources going to the light, one for the cab light switch and door switch and then a constant power for whenever you manually click the light itself to turn it on but that's just speculation.
So just to review incase people suggest or ask certain things. Bulbs are not bad and everything is factory without any changes or upgrades ever done to it.
Any help would be appreciated. Thanks![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
